*Crazy Doro's Audio Blowout*
dorokusai
dorokusai Posts: 25,576
Usher Audio V602 Loudspeaker - Red Mahogany - 9/10 - *SOLD* to Beekyman
This is a very smooth sounding, well built floorstander from Usher. They were purchased brand new, have been lightly used and since I'm the original owner, I'll ensure you're taken care of should anything happen for 6 months. It has a rock solid, warm midrange with a tight low end from a slot loaded enclosure. Don't let the 39hz mislead you, as it has balls. You will not be dissapointed.
The cabinet is mounted on a powdercoated steel, spiked plinth and the Red Mahogany is really sharp to look at. Here are some specifications....
2-way system : tweeter 1" (9930-20NC), low-bass 7" (8935A)
sensitivity: 87 dB @ 1 watt / 1m
nominal impedance: 8 ohms
frequency response (-3 dB): 39 Hz ~ 20 kHz
power handling: 70 watts
crossover frequencies: 2.2 kHz
weight: 24.2 kgs
dimensions (w x d x h): 23.8 cm x 29.2 cm x 103.6 cm
Soundstage Review
I will also ship these anywhere in the CONUS, insured and w/ the original double box packaging.
Includes: Original everything.
Usher Audio S520 Loudspeaker - Piano Yellow - 9/10 - *SOLD*
A killer bookshelf speaker from Usher. These are brand new, never used. I have another pair so it doesn't make sense to have these laying around. I'm the original owner and will honor the manufacturers 1 year warranty. They can be bi-wired or bi-amped and are easy to drive, even at 86db.
They are in brilliant Piano Gloss, Gallardo(Lamborghini) Yellow. They are eye popping to look at and the finish is amazing. Here's some specifications....
2-way system: tweeter 1" (UA025-10), mid-bass 5" (YS-13225W-XP), or (shielded mid-bass 5": YS-13225-2XP)
sensitivity: 86 dB @ 1 watt / 1m
frequency response (-3 dB): 52 Hz ~ 20 kHz
power handling: 50 watts
crossover frequencies: 2 kHz
Hi-Fi World Review
2007 The Absolute Sound, Editors Choice Award
Onix SP3 MkII Integrated Amplifier - Silver - 9/10 - *SOLD* to Beekyman
This is another kick-**** piece and a beauty to look at as well. I'd say it sounds better than the Jolida's that I've heard but that's just me. I prefer it without the tube cage and sliders since I enjoy a nice tube glow. I have some silicon dampers available if you want to go that route. It's a silver, metal flake paint....really cool. Here's some data....
Power: 38 Watts x 2
Tube Compliment: 4 x 5881, 2 x 12AX7, 2 x
6922, 2 x 12AU7
MFR: 20 Hz to 20 kHz
Class AB
Manually Adjustable Bias
Input Impedance: 250 kOhms
Input Sensitivity: 380 mV
Output Impedance: 4 or 8 Ohms
S/N Ratio: >90 dB
THD: 1%
Dimensions: 8.1" H x 11.9" W x
13.25" D
Weight: 56 Pounds
It's been freshly biased, treated with CAIG and comes with brand new Melody 5881 tubes. I have another quad of Melody 5881 that I will include with the amp. It is 4ohm stable and the binding posts are top notch. I thought the amp really opened up with the JJ Tesla 6L6 but YMMV. Either way, you can have alot of fun playing with different tubes in this beast.
The unit was barely used, boxed up and is so fresh that you can still smell the automotive grade paint as if it was new. You'll see what I mean when you open the box.
Includes: Original box, packaging, brand new tube glove, owners manual, etc.
Anthem Pre-2L Pre-Amplifier - Black - 9/10 - *SOLD* to Kkerley33
One of my favorite pre-amps ever and a real high end bargain. It also has a tube regulated headphone amplifier built-in and it sounds great. It drives everything in the Grado and Sennheiser line perfectly. I've added Dynamat to the chassis and all connections have been treated with CAIG products. The included tubes are the original Sovtek but I was using Mullards with excellent results. It's a great pre-amp to roll tubes in and it can be done at reasonable prices. I didn't like Bugle Boy's or Ei in it at all, just FYI.
I'm not sure what you may be running on the front and back end but the adjustable gain feature is really nice. I've owned pre-amps in the past where the gain was so hot that you barely get on the knob, and others where it was so low, you're maxed out. This pre-amp will not have that problem as it's defined by you in 8db(8/16/24) increments. I've always had it set on 8db, and it worked fine for the ever changing 2CH rig.
It's in near mint condition with no known issues. It's remote controlled and uses one of the most common tubes around, the 6922/6DJ8/E88CC. I've owned this series 3 times in my travels and I always miss it when it goes but I'm hooked on this battery powered Welborne, so it has to go.
Includes: Original box, packaging, tube glove, screwdriver, etc.
Spendor S5e Loudspeaker - Rosenut - 9/10 - *SOLD*
One of the first Spendors I've owned and it's a benchmark for me. They sound absolutely gorgeous and if you don't want to marry these speakers after a nice midnight session, you're just plain lame. The build quality is very very high, veneer is rich and the cabinets are almost dead quiet. The are mounted to outriggers and factory spiked.
I WILL SHIP these speakers. They are somewhat small and I have all the original packaging, as well as the double box. These are packaged like a speaker should be packaged. Polk might learn something about that someday. Don't sweat about the shipping as I get killer rates and they will most certainly be insured. I will assist in any warranty issues you may have since I'm the original owner for 1 year. As long as you don't abuse them, you'll be fine. I've never had any issues with a Spendor.
You will need some decent power for these and tubes are a major bonus. I was using them with a CTC BBQ amplifier, Welborne Labs pre-amp and a Wadia 830/Sony SCD-555ES CDP. Stereophile Class B recommended if that's how you roll.
Description 2.5 way floor standing loudspeaker
Enclosure type Spendor 3D linear flow reflex
Drive units HF
27mm coated fabric dome, damped vented enclosure
Drive units LF/MF
140mm ep38 polymer cone
Drive units LF 140mm homopolymer cone
Frequency response
52Hz-20kHz ± 3dB on reference axis
Frequency range
-6dB at 40Hz
Dispersion Within 3dB of response on reference axis
Horizontal over 40° arc ( ±20°)
Vertical over 20° arc ( ±10°)
Sensitivity for 1W @ 1m
87dB
Impedance nominal 8 ohms
Impedance minimum 4.4 ohms
Crossover frequencies 700Hz and 4.5kHz
Power handling 15 - 200 watts into 8 ohms unclipped
Harmonic distortion
<1% 100Hz – 20kHz 90 dB @ 1m
Connections
2/3 way gold plated bi-wirable terminals
Magnetic shielding All drive units shielded
Dimensions H x W x D 790 x 165 x 264mm (31.1 x 6.5 x 10.4in)
Plinth maximum W x D 245 x 284mm (9.6 x 11.2in)
Spikes/feet/stand height 37 ± 3mm
Net weight 16.0kg (35.2lb)
Shipping weight 18.2kg (40.1lb)
Accessories supplied Spikes and lock nuts
Cabinet real wood veneer finishes Cherry, Maple, Rosenut, Black Ash
PSB SubSeries 6 Subwoofer - Black - 9/10 - *SOLD* to Shawn474
I know it's tough sell for subwoofers in the SVS crazed world but this was a standout for me in the 2CH rig. I used this coupled with a pair of Magnepan 10.1 and it blended much better than the SVS 25-31 I used awhile ago. It's been lightly used and I don't recall any flaws when I packed it up. PSB is a highly regarded Canadian company founded by Paul Barton. Here are some technical goodies....
Frequency Range
On Axis @ 0° ±3dB 29-150Hz
Lf Cutoff -10dB 27Hz
Sound Pressure Level
Maximum @ 100Hz 111 dB
Amplifier Power
Continuous 225 Watts
Dynamic 350 Watts
Dynamic Peak 700 Watts
Design BASH, Class H
Discrete MOSFET
Acoustic Design
Woofer (Nominal) 12" (300mm)
Charcoal Polypropylene Cone
Rubber Surround
2" (50mm) Voice-Coil
53 oz (1503g) Magnet
Crossover Variable 50-150Hz, LR4
Low Pass Filter
24dB/octave Linkwitz-Riley
Internal Volume Design Type 2.38 cu ft (67.4 liter)
Bass Reflex
2 x 2 1/2" (63.5mm) Front Port
Radiussed Externally & Internally
Features:
Volume, Crossover (Front mount)
Bypass, Phase
On-Standby/Off
LL/LFE In&Outputs,
Active LL High Pass 80Hz, 12dB/Octave
High Level In & Outputs,
High Pass 100Hz, 6dB/Octave
RCAs & 5-way Binding Posts
Feet with Adjustable
Spikes & Rubber Levelers
Sound & Vision Review 2007
Includes: Original everything. Brand NEW factory packaging.
If you have any questions, don't hesitate to contact me directly or simply post here. Thanks for reading.
055L2PA
0753PSO
573025SAU
004I6SBSP
576206VAU
Post edited by dorokusai on
«13
  • JimBRICK
    JimBRICK Posts: 1,543
    edited October 2007
    Buy that SP3 it is AWESOME. Mine rocks.
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
    mhardy6647 Posts: 35,039
    edited October 2007
    "piano yellow".
  • dorokusai
    edited October 2007
    Huh? It's just what the box says but the website says Gallardo Yellow....who knows. It's super optic tennis ball yellow for sure.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited October 2007
    My eyes are bleeding.....definately a cool conversation piece, never seen speakers produced in yellow......Cool for sure :D
    edited October 2007
    glossy piano lacquer finish, indeed.... but a yellow piano makes me think of the Tele-Tubbies or the Banana Splits or something.
    In fairness, I reckon they're pretty nice sounding.
  • dorokusai
    edited October 2007
    Oh, lol :D My wife was horrified when she saw them and I knew it wasn't going to work out.
  • opus
    opus Posts: 1,252
    edited October 2007
    dorokusai wrote: »
    Dude... your married? No effing way:D
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • dorokusai
    edited October 2007
    Yep, 8 years and she hasn't succeeded in killing me yet.
  • ben62670
    ben62670 Posts: 15,969
    edited October 2007
    opus wrote: »
    +1
    Mark is the real deal.
    Excellent seller.
    Ben
  • dorokusai
    edited October 2007
    Ssssshhhhh, don't tell anyone, I might get an infraction......again :)
  • kkerley33
    kkerley33 Posts: 21
    edited October 2007
    Mark,
    You have an email,
    KAK
  • dagame27
    dagame27 Posts: 599
    edited October 2007
    damn it! if my car wasn't in the shop I would be all over the anthem. If nobody picks this up before I find out how much my repairs are, its mine!
    ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
  • dorokusai
    edited October 2007
    tick tock tick tock
    I believe that Kkerley33(Kyle) is solid but I appreciate the interest Dagame. When you get that car fixed and are back in dagame, drop me a line.
    Mark
  • dagame27
    dagame27 Posts: 599
    edited October 2007
    definitely, thanks Mark. I was looking at this or the Dodd ELP (if I can ever find one) to be my first foray into the world of tubes. I knew yesterday when my car died that one of them would come up for sale. I even told myself to stay off of polkforums for a couple of days. Doh well!
  • George Grand
    George Grand Posts: 12,258
    edited October 2007
    Bring me something nice when you come up and I'll drive you around and buy you pizza again.
  • dorokusai
    edited October 2007
    Chris - No worries as wheels are more important than tubes. I'll make sure you get into some nice tubes whether its with me or someone else.
  • dorokusai
    edited October 2007
    I thought that I was all you needed....hell, I'll even wrap a bow around me.
    There's nothing vintage and cool to bring up George, except that Pioneer "Digital" timer you gave me ages ago.
  • George Grand
    edited October 2007
    Hope you like oatmeal. HEY, I just got an idea!
    If you would've taken that timer apart, you would've seen that I put a Shakti stone in there. Thing's better than an atomic clock, and almost as good as Buddy Rich.
  • dorokusai
    edited October 2007
    The Anthem is *SOLD*. Thanks Kyle :D
  • dorokusai
    edited October 2007
    Talk to me Goose.....
  • kkerley33
    kkerley33 Posts: 21
    edited October 2007
    Giving Mark a Bump. He's got some good equipment listed.
    KAK
  • phipiper10
    phipiper10 Posts: 961
    edited October 2007
    How bout another bump..I'm still crushed I didn't get the green light from the better half for that Anthem!!! It's now officially become an obsession...off to the basement to see what I can sell.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • dorokusai
    edited October 2007
    Thanks guys :D
  • JimBRICK
    edited October 2007
    Big Bump for Mark for that awesome sp3
    2 CHANNEL
    Under construction
  • dorokusai
    edited October 2007
  • JimBRICK
    edited October 2007
    2 CHANNEL
    Under construction
  • markmarc
    markmarc Posts: 2,309
    edited October 2007
    Thanks for posting the link to my review. I meant what I said about fighting the battle to keep the SP3. It proudly sits in my living room, and the glow with the lights off while listening some great tunes is mesmerizing!
    Former Staff Member TONEAudio
    2 Ch. System
  • dorokusai
    edited October 2007
    It's a great review Mark, no problem :)
  • dorokusai
    edited October 2007
    If anyone has questions or wants to deal on the ONIX, Usher or Spendors, just drop me a line. Remember, I'm willing to ship the Spendors and Usher Audio anywhere in the CONUS.
  • dorokusai
    edited October 2007
    I've lowered the price on the ONIX and Spendors.
    *I also added a pair of Usher Audio V-602 and a PSB SubSeries 6i Subwoofer.*
