Amp Help
DTBalla07
DTBalla07 Posts: 10
edited October 2007 in Car Audio & Electronics
I recently bought a kicker KX 700.1 amp for my Polk DBs. I was wanting to use my Polk Momo 300.2 amp for my car speakers. The car speakers are:
Kicker 6 1/2" Coaxial Speakers - Front speakers
65 RMS-130 Peak
Kicker 6" x 9" 3-Way Speakers - Rear Speakers
90 RMS-180 Peak
Would this be okay, or should I go get a 4 channel amp? Amp I was looking at was a Kicker zx350.4. Any help would be greatly appreciated.
Post edited by DTBalla07 on
  • DTBalla07
    DTBalla07 Posts: 10
    edited October 2007
    I went and bought a gel battery. Would a cap still be needed?
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited October 2007
    No need for a cap.
    As far as running all your speakers from the 300.2, it is possible, but not really a good thing to do. You will kill your front stage if you have the rear speakers playing at the same level as the front speakers. I would go the four channel way, this way you could run the rears at alot lower level than the front speakers.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited October 2007
    @ about 1000 rms, you should have roughly a 1 farad cap on the primary power line to your amplifiers. There is no debating me. Have a splendid day.
    PS... why did you get a Gel-cell battery? (if you mean a Yellow Top, its an Absorbant Glass Mat, not a Gel battery, even though many, including myself, used to think it was a Gel) Even so... why'd you get a Yellow Top? Wanna play it with the key off --- get a Hybrid Deep Cycle marine battery, and live large.
    The Artist formerly known as PoweredByDodge
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2007
    Or one of those Kinetic monsters! Theyre a little pricey, but by gawd they got some juice!
  • PoweredByDodge
    edited October 2007
    erm... no, but okay. *puts down his sceptor* ... I give up.
  • MacLeod
    edited October 2007
    You dont like the Kinetics?
  • exalted512
    exalted512 Posts: 10,735
    edited October 2007
    maybe he doesnt like the fact that you spell it wrong.
    -Cody
  • PoweredByDodge
    edited October 2007
    nope, I don't. just a less expensive Yellow Top is all they are. now if I was looking for a Yellow Top and saw a Kinetic, then I'd love it... same performance, less cost = cool. but neither a YT or a Kinetic is going to give you guys what you're after... but I don't run the world, so I keep quiet.
  • exalted512
    edited October 2007
    Everyone in the SPL lanes is running them, so they must be doing something right.
    -Cody
  • MacLeod
    edited October 2007
    Yeah, I see a ton of them in the lanes. You even see a bunch of them in SQ systems as well.
