New H/K Amp...Change Wiring?
SDG16H
I've owned a set of Polk RM67XX/404 for awhile now, but changing out the amp to the H/K 247. Current AVR (old JVC) have wired my fronts into the 404 sub - wondering if anyone has any quick setup tips if they have the same or very similar AVR?
Have heard good things using H/K, looking forward to it...just want to start off right and any help is appreciated...
Cheers
SDG
Cheers
SDG
Post edited by SDG16H on
Hey there,
I own an AVR 247 as well. I am in love with this amp for sure. I have hooked up my RTi8's, CSi5, and FXi3's through the amp rather than doing circuitry through the sub. I find that this is a simple and very effective way of driving thee speakers. I'm sure yours will be similar.
Hook your speakers up, run EZSet EQ and you're off to the races.
I think Bananas are awesome fruit.
HT: Polk Audio RTi8 x2, Polk Audio CSi5, Polk Audio FXi3 x2, Velodyne DPS-12, Harman/Kardon AVR 247, Samsung 245BW Moniter/TV, Yamaha S1700 DVD/SACD, BJC Optical Cable, 12 guage speaker cable, Monster Standard Subwoofer Cable, Monster Lightspeed 1000 Optical Cable, Z-Line component rack, APC SurgeArrest 11-outlet.
http://www.polkaudio.com/forums/showcase/view.php?userid=81835
____________________ -
Yeah, I would hook you sub up to the LFE / Subwoofer Preout with a subwoofer cable / RCA cable, run the other speakers directly to the corresponding HK speaker output, run EZEQ a couple times, make sure your crossovers are set correctly, and you should be good to go.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Thanks much for the replies - that's 3-0 in favour of wiring direct to the amp + LFE - will give it a shot.
