What is the weakest link?
Polkitup2
I am looking for some advice on what my upgrade path should be to best improve my 2 channel system. I am thinking that maybe the NAD or the Denon are the weak spots. Thoughts please? My current two channel setup consists of the following:
Denon 3910 SACD/DVD player
NAD C370 Integrated Amp
Tyler Linbrook Signature Monitors
Audioquest type 8 speaker cables
Audioquest Diamondback and Viper ICs
Post edited by Polkitup2 on
I would vote for the NAD. Just based on how much my t163 veiled my LSi15's before I modded it. I believe the 15's are much less revieling than your Tylers (hearsay - I have never heard any tyler speaker)
If nothing else, I would at least try to borrow a preamp and see if you like the difference it makes. Most decent shops should allow that prior to purchase. (or if you have a buddy with one - all the better)
Just get a good DAC such as the Benchmark. You will see a very nice improvement keeping what you have.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Thanks, I appreciate the input. I play a lot of SACD and I don't think I can get the pure DSD with the Benchmark DAC. It sounds like it would be an improvement for redbook though. I am kind of thinking about a used Audio Research SP16 pre-amp or a used Musical Fidelity A5.
you could also try a nice tube integrated. I lvoe what my stuff sounded like after I got my onix SP32 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
I'd go separates: a tube preamp and a clean powerful SS amp.
Agreed. Your Tylers are begging for more.
And the Denon needs to go. Otherwise, a DAC might work.
Afterwards, play around with ICs.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I would think the Denon and the NAD. The Denon is a nice player though.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I think the NAD. Adding a DAC would be the easiest / cheapest upgrade for redbook CD. Changing the NAD out would be more costly, but maybe a better overall upgrade, long-term.
I like my MF A3.2 very much. I'm sure the A5 would be that much better.
If you just want to change things up, you could get Polkmaniac's Music Hall integrated. It's so cheap that you can play with it and resell very easily should you go a different direction. Likely no better than your current NAD, but likely a different sound.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Good choice on the SP16; I've had mine for almost a year. Very few pieces make it that far with me_________________________________________________
I think there are better amps.engtaz
Your system looks great to me, but if pressed, I'd replace the NAD.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Biggest, most instantaneous difference I ever heard was when added my Rogue Audio preamp or when I added GIK Acoustic treatments to my system.
I like that Rogue Audio Perseus pre-amp, has the HT bypass which I want.
My guess is that the NAD is the weak link
There is no doubt that you need more than your NAD can provide.
With the NAD C370, is it the pre-amp or the amp that is the weakest link, the reason I ask is that I could buy a pre-amp and use the amp section of the C370 or use a NAD C270 for the amp which I have as well. If both the NAD components are weak links I think I would be best off looking at an integrated like the A5.
I think your biggest upgrade would be to run out and grab some music as your system is very very nice (The NAD is VERY underated.) and without mentioning specific areas in which you wish to improve I'd take my advice and buy some new music. It's been a great year for music.
Another plus for the GIK panels (or any others I guess); my case is probably an extreme example...but my 10x13x7 room has 14 panels. It went from horrible without them to being capable of listening at relatively high volumes like if I was in a room three times the size. In my next life the first thing I'll buy are the acoustic panels_________________________________________________
Since you got rid of your Tyler's you should probably think about ditching the ARC. Maybe put it on the flea market with a really great price!
I will, when I can get something like the Dodd reference for the same price_________________________________________________
Yup, more than likely the room you've got them in is the weakest link. My room was too, right up until my ears went south. Totally cured upgradeitis like you wouldn't believe.
Thanks everyone, I'll check out the room treatments. Actually thought about making some at one point.
What do you want it to do better? If its high volume slam you want, then a better amp. If its clarity, its a pre amp. But the room treatments will help both. Dacs will help but since you use sacd I dont know. More music is always a great upgrade! Have fun.Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
I am not sure what I want, I just want more. My rig sounds good if not great to me as is, so I guess I want more greatness. I don't need high volume, I believe I seek transparency - no veil whatsoever. Clarity, silky smooth liquid sound.
