critique my car audio system
eagles fan
Hello;
I drive a 99 Chevy Silverado, just had a KenwoodKDC MP435U 50w/channel USB port, blue tooth capable etc along with 4 Polk DB461, 4x6 speakers installed. Then went and had and MTX Audio Thunder Amp, 50 W/channel installed.
I really don't know alot about car sound systems other than the initial setup distorted at fairly low volumes, with the Amp it sounds pretty good.
Does the 50w/channel amp add to the 50w/channel coming from the receiver?
Does this sound like a decent setup?
Is MTX a decent AMP?
Should I have gone larger on the AmP?
Install a Sub?
I'm fairly content with the setup other than trying to navigate through the menu's on the receiver but always looking to improve. I want to hookup the blue tooth. Kenwoods website sells them for around $175.00. The place that installed the AMP will buy it and install for about $250. I think I'll do this one myself. Is there a more generic way to get my cell to work through the receiver, rather than using Kenwoods products?
Thanks for your help. I know lot's of questions
Install a Sub?
Post edited by eagles fan on
eagles fan wrote: »Does the 50w/channel amp add to the 50w/channel coming from the receiver?
First off, your receiver was putting out more like 7 watts per channel. Not 50. But the answer is no. The receiver sends out a passive (without power) signal to the amp so youre listening strictly to the amp.Does this sound like a decent setup?
YesIs MTX a decent AMP?
Very much so.Should I have gone larger on the AmP?
A friend of mine put it best. "Get as much power as you can afford." However, 50 watts is fine.Install a Sub?
If you want the best, most accurate reproduction of music you should.polkaudio sound quality competitor since 2005
WOW!
That's not what I expected. Thank you thank you! Very positive, to the point.
So my Kenwood is only putting out 7watts. I believe that though. Can you explain this a little bit. Even though it says 50 watts per channel. The guy that installed the amp said something similar to what you said except I really couldn't understand him.
thanks again for a great response.
Jeff -
Stereos and Amps have 2 diffrent power raitings, 1 is called RMS ( the only one u need to pay attention to)2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
It is not that they have two different ratings, it's that people go by the max ratings on the HU's instead of the RMS ratings. All of my HU's have stated their RMS power ratings, as well as the max ratings. Many amplifier makers also do the same thing. Still, I would not go with HU power. My wife on the other hand is quite happy with her system being powered by an Alpine CDA-7894. This HU puts out about 27 watts RMS.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
