Carpet spikes
Hello,
I bought a pair of Rti10 2 weeks ago and the spikes are doing marks on the floor.
The floor is made of pine boards.
My question is can I remove the spikes, if not, is there something I can put under the spikes to prevent marks?
Than you,
Bert
Than you,
Bert
________________
Pioneer Elite VSX-01TXH
Mains: Polk Rti10
Center: Polk Csi-5
Surround: Rc-65i
Back surr.: Rc-85i
Sub: SVS PC-Ultra
Mains: Polk Rti10
Center: Polk Csi-5
Surround: Rc-65i
Back surr.: Rc-85i
Sub: SVS PC-Ultra
Post edited by Berty on
hmmm... carpet spikes are supposed to be used for carpet, I’m pretty sure that you should be removing them if you have a pine floor.Testing
Testing
Testing -
Take them out or put something underneath. They should just screw out and then you can get spikes for floors and not carpet ones.Michael
NORTH of 60° -
Here are a couple links that have a number of spike/disc choices.
http://search.ebay.com/_W0QQsassZsolid_spikes
http://www.myesound.com/Page3.htmlHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I don't know how many versions of these speakers were put out, but if they are like the pair I have, then you will not be able to remove the spikes due to the plastic decorative piece at the bottom front of the speaker.
Until you get some rubber feet, spike footers or another temporary alternative, try drilling a small divot in the center of a quarter X 8, setting the spikes within the divot. For the ghetto temporary fix, take a phone book or short 2x4's and place speakers on top with the spikes removed.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
get a pair of ceramic tile -- works great, used it ever since I got my Taylos...
I also put floor saver foam pads under the tile so I can slide my speakers around- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank you guys for the replies.
The links from Dennis are interesting solution.________________
Mains: Polk Rti10
Center: Polk Csi-5
Surround: Rc-65i
Back surr.: Rc-85i
Sub: SVS PC-Ultra
