Polk equivalent of Axiom M50
hdr77
hdr77 Posts: 3
edited October 2007 in Speakers
Hello,
Can somebody tell me what you feel is the closest match in polk speaker line up to Axiom M50 and QS4 with respect to max audio output ? I am asking this question because I was suggested the Axiom Epic50-350 by one of the audio specialists and unfortunately Axiom is not available at my place but fortunately the polk is. I really dont wont to buy something which will under power my room and I am planning to drive the speakers with an Onkyo 605.
Post edited by hdr77 on
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2007
    Atrium 45?
    I'm kidding brotha...I have no idea.
  • Doc99
    Doc99 Posts: 100
    edited October 2007
    I would say the RTi8
    F1nut Posts: 51,794
    edited October 2007
    Polk doesn't make anything that bad.
  • hdr77
    hdr77 Posts: 3
    edited October 2007
    The sensitivity of RTi8 is around 89db and for Axiom M50 its around 93db. I think this is going to make the power requirement for Rti8 almost double that of M50 to produce the equal amount of SPL, is it true ? And if so will it make a huge difference in filling my room with good sound while driven with a Onkyo 605 ? Axiom Epic50-350 was suggested as the minimum requirement considering the volume of my room.
  • steveinaz
    edited October 2007
    Keep in mind, efficiency has nothing to do with quality. 89dB is still a very efficient design.
  • hdr77
    hdr77 Posts: 3
    edited October 2007
    Yes, I do realize that polk systems are engineered to perfection and 89dB is quite good. But my concern here is will a 90W RMS system be good enough to drive and create the same SPLs and thereby the HT experience as 93db Axioms driven by the same amplifier (I think the power requirement doubles for polk to create the same SPL as Axioms? I have seen in many threads that 150-200w speakers needs good amount of power to sound good and create the SPLs as required. Thanks.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited October 2007
    Seeing as you are, at most, using 10 W/channel, I'd say you're fine.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • bignorm
    bignorm Posts: 120
    edited October 2007
    I heard that........AXIOM SUCKS
    Eliab/Dave Abrams calibrated Panny
    Yamaha,Denon,Toshiba "in the rack"
    Polks all around
    SVS on the floor
  • OnlyPolk
    OnlyPolk Posts: 137
    edited October 2007
    http://www.goodsound.com/home.shtml
    Perhaps most of you have already seen this, but I thought it to be a very frank admission of bias on the part of at least one tester of equipment. After some 20 years I had been recently looking for some good floorstands for music. I read a lot of reviews from stereophile etc. (on line) and I noticed that (1) they used amp. sources I could never afford (2) they had conclusions that didn't mean a hill of beans to me like "I found the mids to be a little clearer". In the end as I did 20 years ago I just picked something that many people seemed to agree on, would suit my budget and would mesh with what I already have. I keep wondering though if all reviewers did blind testing, what would they really recommend?
    (This is just a comment, not intending to stir up a discussion)
  • ABX
    ABX Posts: 109
    edited October 2007
    You can do better then Axiom
