Center channel choice with RM40T front speakers
rbutterwood
Hi,
I am about to purchase a Polk center channel speaker to accompany my RM40T front speakers. Which would you recommend?
The CS2 looks the best but retails at $299. The CS1 is available for $105 on Amazon. Is it worth spending the extra $194 for the CS2?
Thanks.
Thanks.
Post edited by rbutterwood on
rbutterwood wrote: »Hi,
Thanks.
I'd suggest you call Polk tech support. I did that a few days ago after not getting any responses on this forum about possibly upgrading my RM202 center speaker.
My guess is that they will suggest another speaker in the RM series because it will be "matched" to the RM40T's you plan to buy.Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
