Quieting a Dehumidifier?
Early B.
I purchased another dehumidifier a couple of years ago. At first, it was whisper quiet. Now the damn thing sounds like a blackhawk helicopter. Same thing happened to the last one I had. Even though the dehumidifier is in the basement, I can hear it on the main level. Are there any tweaks to temper the sound?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Turn it off... The sound will stop.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »Turn it off... The sound will stop.
Damn I saw the title of this thread and thought "Im gonna be a smart **** and tell him to turn it off"
Looks like someone beat me to it!
Sometimes I throw a blanket over mine......hasn't really affected it much since it can still suck and blow air through the blanket.... -
Ok now on a serious note. I think fan / blowers that are designed as a fan cage can get dirty and become out of balance. I would disassemble unit and clean anything that moved and see... Other then that the fan / blower bearings get loose and cause the blower to vibrate causing noise.
Sorry to say they design the thing to live for X hours, so you need to buy another one. It's a design factor to keep them in business.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Ok now on a serious note. I think fan / blowers that are designed as a fan cage can get dirty and become out of balance. I would disassemble unit and clean anything that moved and see... Other then that the fan / blower bearings get loose and cause the blower to vibrate causing noise.
Good idea about cleaning it. Thanks.
Yeah, I'd hate to replace it 'cause it works great. A Sears Kenmore unit.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
You could always get yourself a set of those ear protectors you wear at the shooting range...then you wouldnt have to listen to it.
