mini USB hardwire in my car
BaggedLancer
So I decided I want to put a hardwire charger for my TomTom in my car. Question is, I found this:
http://cgi.ebay.com/DIRECT-HARDWIRE-CABLE-TOMTOM-ONE-XL-POWER-CHARGER-TOM_W0QQitemZ110174306445QQihZ001QQcategoryZ73350QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
But that is $31 for a hardwrie mini usb 5vdc cable and I feel like I could do the same thing for a 1/5th of that price. Any have any idea the easiest way to do this? Buy a replacement cigarette adapter and cut the plug off or just suck it up and spend $31 on a cable.....
Post edited by BaggedLancer on
If you can find out what wire is negative and positive, youd just hook that up. The only thing that worries me is the converter thing. If it knocks it down to 6V or something, youd fry your piece.
Yea, this is entirely more complicated than it should be.
I have another idea on my mind and im gonna stop an an auto parts place on the way home tomorrow. I just cant stand wires all over my dashboard, looks like crappppppp -
the tom tom didnt come with a car charger?kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
it did, i want to hardwire it. no cigarette lighter adapters, looks tacky. -
how do u plan to hardwire it and hide the wires?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
Run the wires behind the dash and right into unit after I figure out how I want it mounted. I have no intention of using the windshield mount, yuk.
hardwire a cig lighter behind the dash would work
or
http://cgi.ebay.com/12-5V-Car-cigarette-lighter-outlet-to-USB-power-charger_W0QQitemZ120169696764QQihZ002QQcategoryZ57244QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
somethin like that -
Neither of which I want, both half assed ways to do it. I want a single wire with positive and negative on the end that I can wire directly into my fuse panel accessory slot using the correct amp fuse.
No extra cigarette lighters
No cigarette lighter adapters
Thanks though. -
well since its 5volt source voltage for usb, you will need either a dc adapter or a step down tranformer inline or something like that. A cig lighter plug would hide behind the dash super easy
I would need something exactly like the wire I linked. I was just wondering if there was a cheaper place to buy it.
gotcha, it looks like the wire you linked is ur best bet then
unfortunately it looks that wya
Got the new mount and disc in today, after I hardwire it into that console you won't see the ugly wire.
When I'm not using it the arm comes off and I can close the little door to cover everything up as well as the hardwire when it's not in use. -
That looks awesome!!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
