MM2104 Question
wheelerdh
I have two Polk MM2104's and I know they are rated at 300 watts RMS. Are these numbers underrated, and if so what RMS can I safely run them at?
Post edited by wheelerdh on
i have a little over 600 watts RMS running into them, and the hit insanly hard and are very loud to where i can feel my hair vibrating, what kinda car are u putting them in, because u may not need as much power as u think2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
The safest thing to do is to run 300 watts each to them.
However, so long as you use common sense with the gain setting and in using the volume you can run more.polkaudio sound quality competitor since 2005
I agree with 300 watts RMS. You will see amplifiers underrated and that is godd but for the most part speakers RMS figures are not. Although you have a max rating that gives you some play. Besides when listening to music you never realy know how much power have but it is usually less than you think. Go with more power just make sure you listen to distortion free music.
most of the time the RMS is underated but I wouldnt go much higher than that
Hello all
Are there any decent amps for these subs around $200.00? -
sure r. how many r u trying 2 run? 2? cadence ia7 powermaxelectronics.comPolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
or you can try TMA T1000...they are going for $208 online. Made by JL audio.CAR:
- Kenwood DDX6019
- MM6's & DB6501
- Rockford P400-4
- (2) MM2104's
-TMA T1000.1
HOME:
(no polk gear yet....still wishing)
