HD DVD / Older Mits HDTV/1080i max
Ethancf
Ethancf Posts: 481
edited October 2007 in Electronics
Hey all,
It's been a while. So HD DVD is coming down in price. My 65" Mits has 480i/480p, and a max resolution of 1080i...yes I was an early adopter. I bought a component video switch that has 3 component video bays...in other words, out from 1080i port on Mits TV via component to the component video switch then one out to my DirecTV HDDVRPlus at 1080i resolution, one out to my XBox360 at 1080i resolution, and I have one more that I was thinking about filling with an HD DVD Player. My current DVD player is a Sony NS999ES (480p...sweet player though).
I don't have HDMI at all in my setup. Can HD DVD players do 1080i via component, or do you have to have an HDMI TV and are these players HDMI only, and is 1080p the only resolution to get high definition in DVD? Just want to know if I'm stuck with what I've got or can I spend MONEY and be dazzled with HDDVD at 1080i via component?
Cheers!
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2007
    Yes you can go for the HD DVD player and you will still notice a huge difference even in 1080i. Being that you can run the player in 720p or 1080i to determine which setting looks the best on your display. I currently run my XA2 via 1080i until I get my new theater room done and 1080p projector in place. So you'll be fine running component with the HD DVD player, however you wont get upconversion of SD DVD via component, only via HDMI. So go ahead and go for the HD DVD and dont look back.
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2007
    You will definitely notice a huge difference. Get XA1 - you will get 1080i through component, and true HD sound through analog outs to your receiver.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Ethancf
    Ethancf Posts: 481
    edited October 2007
    Thanks for the replys. So given my circumstance and limitations above, what are your favorite players/models? HD DVD or BluRay? I've been a Sony high end dvd guy since the S7000. Does Sony do a BluRay that will do component at 1080i? Do both players have setup options in the players that allow you to select your max resolution? Does 1080i look much worse than 1080p on an HDDVD or Blu Ray disc?
    Thanks!
    THE SYSTEM
  • Sherardp
    edited October 2007
    Sony has the BDP S1 which is very much on par with the ES line. Go for both and yes you can configure both players to output @ 1080i or 720p. As for HD DVD for an XA1 or XA2 since they will give you the analog connections you need to enjoy HD audio.
  • BIZILL
    BIZILL Posts: 5,432
    edited October 2007
    you'd be hard-pressed to notice a difference between 1080i and 1080p. i have a 5 year old 65" rptv as well. never seen a picture so beautiful before. kicks the **** out of hd cable and satellite. have yet to experience any pixelation. bandwidth is there. no probs. if you want to save yourself a component slot, then you could go with the xbox 360 hd dvd add-on and use your existing 360 connection. only thing, no up-conversion through component unless you rip the movie and strip it of any encryption. my tv has dvi so i use an hdmi/dvi adapter and all is well. (with my ps3)
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
