hooking up rm6750 using bass managment
dx31698
dx31698 Posts: 13
I have these speakers and just got a new onkyo 705. On this website it says to hook the fronts into the sub and then into the receiver. it then says set fronts to large and others to small. My onkyo doesnt have large and smallit use 40hz-200hz. It has full band as an option so im assuming thats like setting the fronts to large. but i dont know what to set my center and surrounds too. How many hz. Can anyone help me
Post edited by dx31698 on
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    100hz all around. 80Hz is the standard but those speakers wont give you much below8 80-100 hz. So I would stick with 100hz.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • VSchneider
    VSchneider Posts: 443
    edited October 2007
    jakelm wrote: »
    100hz all around.
    make that 120 Hz, actually
  • Jim Shearer
    Jim Shearer Posts: 369
    edited October 2007
    If you are running the front speaker wires to the sub then to the speakers: set the fronts to full range. If you set up through the sub, then only way you're going to get any bass is to set the fronts to full range (no freq limit.) If you set the fronts w/ a freq cut-off, then you will lose the bass. On the sub, set the crossover to something in the 100-120 Hz range.
    If you use an LFE (line level) output to the sub's LFE input or pre-outs to sub's L/R line level inputs, then follow the advise from Jake and VS.
    Cheers, Jim
    A day without music is like a day without food.
  • Willow
    Willow Posts: 11,306
    edited October 2007
    I say you are best running it like Jim first mentioned large and no sub and through the sub.
  • MLZ
    MLZ Posts: 214
    edited October 2007
    Unless you have a SPL meter and test tones, why don't you just use the receiver's Audyssey's MultEQ XT for room calibration?
