Question on wiring RC6s
mrankin22
I purchased the RC6s which has left and right connections to provide stereo sound from a single speaker. I am going to use the RC6s as a rear center speaker; however, my basement only has one pair of speaker wires pre-wired to that location.
Any recommendations on connecting the RC6s with a single speaker wire? Should I simply wire only the R or only the L connection, or should I jumper the L and R connections together and then wire to one of the posts?
Thanks.
RC6s option #1
R+ --> Connect to receiver Rear+
R- --> Connect to receiver Rear-
L+ --> No connection
L- --> No connection
RC6s option #2
R+ and L+ --> Connect to receiver Rear+ (jumper R+ and L+ at speaker)
R- and L- --> Connect to receiver Rear- (jumper R- and L- at speaker)
Thanks.
RC6s option #1
RC6s option #2
