Dual PSW404 or single SVS PB12-Plus
jmuma2k
Hello,
My current system consists of (2) RTi10, CSi5, (4) FXi3, Denon AVR987, Audiosource AMP300 for fronts, and Audiosource AMP100 for center. I also have a PSW404 which seems to be little underpowered for my room. My room is 14'x19', which includes a stairwell going up. I know my room isn't that big however I would like a little more chest punch.
The cheapest option would be to go with another psw404 which would cost under $250. However I was seriously looking at a SVS PB12-Plus which would cost me $800 and then I might be about to get $100-150 for my used PSW404.
I guess my question is. Would another PSW404 be enough to add enough pressure to the room to give a noticable difference? Or should I just save up and go with the SVS?
Thanks,
Josh
Thanks,
Josh
Post edited by jmuma2k on
Go with the SVS. I had the PSW404 and it was less than impressive. If you want to go with Polk subs, go with dual stacked PSW505's. The 505 is the best of that series. Polk also has some new subs that are getting good comments, you might check them out.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Go with SVS, best bang for buck sub out there. Or check out Elemental designs, I have been reading allot of good compliments on their product as well, granted I have never heard one. I can vouch for the SVS though.Shoot the jumper.....................BALLIN.............!!!!!
Elemental Designs if you don't mind the finish. I have a A5-300 which has been discontinued and replaced by the A5-350. It has no problem pressurizing my listening area which consists of a 15x10 room that's on a slab and is open to another room 10' wide."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks, I think I am just going to save up and spend the money on a SVS. They are located like 4 hours from me, so maybe I will see if they have a demo room or something like that.
Josh -
The choice is easy, SVS.
my advice would be to save up for the sub you really want and live without one until you can get the sub you really want. I don't know much about the smaller SVS's but I know there is no current Polk sub that is even close to the same league as my current SVS.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
