2 Carver M-200t's bridged to 10a's
lightman1
lightman1 Posts: 10,800
edited October 2007 in Vintage Speakers
Not to sure about the common grounding on the C's. Yea or Nay on bridging one amp per speaker. Any thoughts?:confused:
Post edited by lightman1 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2007
    On 10a's? Sure, bridge away. Two M200's will out hump an M500.
    Cheers,
    Russ
  • avguytx
    avguytx Posts: 1,628
    edited October 2007
    That should work ok. It's not SDA's so there's no problem with having to have a common ground amp. What impedance are the 10a's? That could be the only dilemma if they are lower than 8ohm then the 200t's might not like it. What does the amp manual say?
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • engtaz
    engtaz Posts: 7,674
    edited October 2007
    The problem with mono amps and non common grounds is a SDA problem.
    engtaz
  • avguytx
    edited October 2007
    Russ! Waddup man?
  • danger boy
    danger boy Posts: 15,722
    edited October 2007
    engtaz wrote: »
    true. unless your amp is a dual mono design.. i know, i know.. we're talking true mono block amps here. ;)
    PolkFest 2012, who's going>?
  • lightman1
    edited October 2007
    Measured a little over 7 ohms. Just wanted to be sure before I accidentally let the smoke out of the amps. Heading to the "room" right now. Thanks guys.
    Russ in NC
  • lightman1
    edited October 2007
    avguytx wrote: »
    Russ! Waddup man?
    Russ in TX or Russ in NC. Either way, Howdy back atcha!
  • avguytx
    edited October 2007
    Ahhh...I didn't know your name was Russ, too! But waddup to both!
  • lightman1
    edited October 2007
    Messin' With Texas. Nice to meet ya. Just finished bridging the M's, let 'em warm up. Put Donald Fagan Nightfly. Much better! The low Hz was cleaner and a tolerant level. Thanks again.
    Russ "The" lightman.
  • TroyD
    TroyD Posts: 13,124
    edited October 2007
    I had an m200t that I got from Russman.....sweet little amp. Rock on.
    BDT
  • opus
    opus Posts: 1,252
    edited October 2007
    Not sure but I think I now have that amp. Still rocking:)
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
    treitz3 Posts: 20,239
    edited October 2007
    lightman1 wrote: »
    Could you Bi-amp instead with those speak's?
  • lightman1
    edited October 2007
    treitz3 wrote: »
    No. Only one input to the X-over. Bridged and rockin' !!!!! Don't need it loud. But the juice is there when needed.
