A question for Grimster 74
dholmes
I noticed that you have 2 svs subs, may I ask how big is your room? Also what is the size of your av cabinet? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I have dual subs as well, per recommedation of the Grim. Im also using the SMS-1 to work out any peaks. My new dedicated room will be 17x22. What questions do you specifically have in regards to subs?Shoot the jumper.....................BALLIN.............!!!!!
Thanks Sherardp for pointing this thread out to me, always looking out for a brother. Dholmes, my room is a little bit smaller than Sherardp's room, mine is 14.5' x 22' x 8'. My a/v cabinet is roughly 2' deep, 4' wide and 2.5' tall. The interior shelves are 19.5" wide and 1.5' deep that way I have plenty of room for wire management. Hope this helps.Money Talks, Mine says Goodbye Rob!!!!
Thanks guys, I was thinking about adding another sub & my set-up is like Grimster74,did you build that av stand or did you buy it?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Grimster74 I forgot, is that a basement,concrete floor?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Yes, my basement is a concrete slab. As far as the stand, yes, I built it myself.Money Talks, Mine says Goodbye Rob!!!!
Thanks ,A+ ht you have!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Dholmes, just in case your thinking of building your own a/v stand, here is the link to my build.
http://www.polkaudio.com/forums/showthread.php?t=49845&highlight=grimster74Money Talks, Mine says Goodbye Rob!!!!
