WTB RT2000p / RT1000p / CT400i Drivers
Whateverer
I'm looking for a RT2000p crossover.
2 RT2000p / RT1000p mid range drivers I'm pretty sure there the same just might have different stickers on them as to what speaker they where in I forgot to get the driver model numbers but ill get them later.
And two tweeters I think the 2000p 1000p and CT400 tweeters are all the same.
If anyone has any of these or knows where I might be able to get them I would really appreciate it.
Post edited by Whateverer on
Got the model numbers of the drivers I need,
Two MW7011 mid / Midbass drivers
And two SL6502 tweeters.
The xover I don't think has a "model number" but ill check tomorrow.
Thanks! -
The MW-7011 drivers are discontinued and Polk now recommends the
RD7200-1. There 75.00 plus shipping and handling straight from polk audio. I think you get a discount if you mention your a Club Polk Member. -
nikolas812 wrote: »The MW-7011 drivers are discontinued and Polk now recommends the
Do you know if they are a direct fit? Also I'm wondering if they sound about the same or how similar?
Ive also read that the SL6511 works as a replacement for the SL6502. Does anyone know if this is essentially the same tweeter? Or that it sounds similar, etc?
