Slot A or B, computer questions
kn505
kn505 Posts: 380
edited October 2007 in The Clubhouse
I have noticed that there are many computer experts here. I am calling for your help.
I have an older Dell laptop which has two 128M RAMs. In order to improve its performance, I bought a 512M RAM. Should I install this new RAM into slot A or B? Should I install the 512M with the old 128M? Or just use the 512M only?
Thanks in advance for your help.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Use both 128 and 512, if your laptod can handle 640 RAM. If it can, it really doesnt matter what order you put them in (to my knowledge).
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Shizelbs
    Shizelbs Posts: 7,433
    edited October 2007
    Is each stick of RAM rated at the same speed? Not sure about laptops, but I know desktop mobos can accept RAM of different speeds depending on the chipset. Just make sure they match. It shouldn't matter what order you put them in.
  • kn505
    kn505 Posts: 380
    edited October 2007
    Thanks for your helps.
    I didn't check the speed, but they are both pc2100 RAMs. I think their speeds should be the same.
