wiring question
sageleo
Now my question is with my old set up I was using a seperate powered sub connected via sub pre out to back of sub. My new setup is rt20p with built in powered subs, but I'm not using sub pre out on my avr, I'm just using my speaker wire and have speakers set to large with sub set to off on my avr. I guess the question is am I losing and sound quality by doing it this way?
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
I think that is exactly the way to set it up."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Nope - you have it correct. (anything going to the LFE channel should be redirected to your front speakers.)
sweet thanksT.V.- Sony KDL50W800B
