replacement woofer
sageleo
sageleo Posts: 170
edited September 2007 in Speakers
I'm not really sure if this is where I should post this question so sorry. I need a replacement woofer for one of my rt20p's and I'm not sure where to get one or if there is a specific woofer needed. If someone could help me out I would be grateful. Also I dont have a manual for the speaks, and cant find one online if anyone could help me with that also. thanks.
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • seeclear
    seeclear Posts: 1,243
    Maybe try the Troubleshooting section? Ken from Polk monitors that more closely, I think, and he could definitely point you in the right direction.:o
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • sageleo
    sageleo Posts: 170
    k thanks will try there, appreciate it.
