Need painting tips for inceiling speakers
Zamps
Zamps Posts: 48
edited October 2007 in Speakers
I have some in-ceiling speakers that I'm going to paint to match the room color. I'm wondering if anyone has any tips on painting the covers. The instructions recommend using spray paint, but I'm having trouble finding a match.
Any suggestions would be appreciated. Thanks.
Display: Mitsubishi 52" WD-52527
AVR: Denon AVR-1909
DBS: DTV HR20-700
DVD: Samsung DVD-P421
Video Game: Sony PS3, Wii
CD Changer: Sony CDP-CX335
Fronts: Polk RT800
Center: Polk CS400
Surrounds: Polk TC80i (4)
Sub: Polk PSW450
Misc.: Monitor 5JR
Post edited by Zamps on
    treitz3 Posts: 19,950
    edited September 2007
    You have a friend with an airbrush setup? Sand/scuff/prime/paint using custom color match. You can use Testor's paint as a tint or you can have a professional paint shop color match a quart of whatever type of paint you want.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I considering the same thing and wish to use the room paint, but......
    It maybe to thick and block to holes up. So when ever I had this issue painting anything else with hole or slots I reduced the paint. If latex paint I reduce with a little water in a separate container and rolled it on then back brushing any paint which started to cover a hole or slot.
    Well just my $.02 but it's worked for me.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dorokusai
    dorokusai Posts: 25,576
    Spray paint works best in my travels. Just how close of a match do you need? The grills are ready to be painted right out of the box, no sanding is needed.
  • Zamps
    Zamps Posts: 48
    disneyjoe7 wrote: »
    I'm worried about clogging the hole also. Thanks, I'll give that a try. I have plenty of extra paint and would like to use it for a "perfect" match. I think a coworker might have an airbrush so I might investigate that a little further.
    The spray paint that I found was either too dark or too light. I'm trying to match a paint called "Mocha Dream." It sort of a taupe/light brown color.
    AVR: Denon AVR-1909
    DBS: DTV HR20-700
    Fronts: Polk RT800
    Center: Polk CS400
    Sub: Polk PSW450
    Misc.: Monitor 5JR
  • Barnestormer
    Barnestormer Posts: 27
    As I am getting ready to perform the same task, I did some searching in the old threads and found someone who used the same latex paint, but slightly thinned. Applied with a brush and then used compressed air to blow clean the grill. Nice if you have access to a compressor, but the small cans you get for cleaning keyboards, etc.. would also probably do the nice.
    Eric 'Barnestormer' Barnes
    Rollover Ratio - .5:2 :confused:
  • dorokusai
    A safety pin comes in handy for popping paint from holes. Sit down while you watch Faces of Death or a nice childrens' movie and poke away.
  • Zamps
    Zamps Posts: 48
    I like that idea, I'll have to pick up one of those cans. If I see the Cars movie one more time I may inadvertantly poke my eye with the paper clip. :)
    AVR: Denon AVR-1909
    DBS: DTV HR20-700
    Fronts: Polk RT800
    Center: Polk CS400
    Sub: Polk PSW450
    Misc.: Monitor 5JR
  • jzpasnu
    jzpasnu Posts: 12
    edited October 2007
    I recently spray painted the grills of my Polk inwalls with no problem. I used a cheap Black and decker spray gun with the same paint I used on the wall. I was concerned that it was going to be too thick but turned out fine. Just make sure you apply very light coats with the gun firing in a steady back and forth motion across the grills.
  • wz2p7j
    wz2p7j Posts: 840
    edited October 2007
    When I cut the hole for the speaker out of the ceiling, I took the piece up to Home Depot and had them color match it with interior flat paint. I used a touch up brush thingy to actually paint the grille. It's hard to describe - it has a little red plastic handle and a little pad about 2 X 3 inches square (also found at Home Depot). I think it's supposed to be used to paint where walls intersect other walls or ceilings. If you dab the paint on lightly, it won't clog the holes. I do remember doing some huffing and puffing to blow holes clear with my mouth that got a little too much paint over them. If I had a little compressed air handy, that might have helped. The end result was very satisfactory - just about a perfect color/texture match and no clogged holes. Chris
