CS245i
Hi,
I need some help.
I'm looking to replace my CS245i, but I'm not sure which model is the closest equivalent.
Any suggestions?
I want to ensure that it's a comparable model or one step up.
Please let me know.
Thank you!!!
I need some help.
Any suggestions?
Please let me know.
Thank you!!!
Post edited by flipper on
The CS400i has the same tweeter, so it will be sonically very similar. It is a popular model and will definitly be a step up.
Upgrading from CS245 to CS400 made a world of difference in my HT.
Note, you'd want center channel speaker to match your mains. So what model # are you speakers?Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I have a mix/match set that I put together of the years. Bose 301 Fronts and Paradigm rear speakers.
My CS245i was damaged by water so I've been looking to replace it with another Polk Center.
Looking at the website I see a CSi3 and a CSi5. I don't know much about audio, but now that I need to replace it...I'm learning more and more.
I want to find something equivalent to the CS245i or one step up...The thought is CSi3 or CSi5.
But you probably know better.
Thanks so much!!:)
