What is wrong with this ad
jtgranby
Post edited by jtgranby on
The dude wants 350 bucks firm for them ? -
SL1000's in one speaker, 2000's in the other?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
good eye Russ
I didn`t know the cable was still available eitherCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Why does one speaker have fuses and the other does not?SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Why does one speaker have fuses and the other does not?
The one with the fuses is an early version, the other a little later. This means they are a mismatched pair and should be avoided at all cost.Political Correctness'.........defined
President of Club Polk -
The seller is on meth.
Russ
I should of said polkies with less than 10,000 posts.
The same seller also has the stands in a seperate ad and as F1nut said avoid these at all costs
JT -
I wouldn't have bought them for $250 (no less $350), even if they were consecutive serial numbers and matched like a ****. It takes a special kind of douchebag to sell the dedicated stands in a different auction. That speaks VOLUMES about the seller.
I think the better question would have been to ask:
What is correct about this ad? -
the seller wrote:A: Hi, Thanks for pointing that out, the right speaker cabinet has silver tweeters and the left has black. I didn't know the differences, I just thought they made them that way.
See? There you go. He thought they were just made that way. All just an honest mistake.
TO ADD: Polk does make them that way... no? HA, ha, -
I checked 'em out, too. This guy is smokin' the skunkweed! My theory is he could only carry one speaker at a time when he robbed the house. Then had to hit another to make a pair. Stay far away from these.
Relisted for $220. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290165674129 :rolleyes:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
