Got new speakers, will they work with exsisting HT reciever
n_e_w_d_u_d_e
hey guys, this newby needs some info and advise. Okay currently i have a Panasonic SC-HT900 5.1 hometheater system.Here's a weblink to what it looks like:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vModelDetail?storeId=15001&catalogId=13401&itemId=64104&catGroupId=25011&modelNo=SC-HT900&cacheProgram=11002&cachePartner=7000000000000005702
I bought it a couple of years ago at best buy. Its one of those setup were its a 5 disk DVD player, and reciever in one. Actually the the DVD player hooks up to the subwoofer were the rest of the speakers hook up to. It's a 1000 watt total system. It suits me for watching my movies. Now my overall plan is to slowing upgrade this whole system. currently I bought a C150 center channel from 1995 i found at a pawn shop for $30 and its now my new center channel speaker. I also have a pair of Vintage montior 5jr bookshelf speakers i found at a pawn shop and will getting them friday to replace the front surround speakers that came with the setup. When christmas comes i hope to buy some of the R50's to replace those and move the Monitor5jr as the rear surround speakers.
Now my roomate has been telling me about when you get speakers make sure they are ones that will not fry you reciever. Something about the ohm's being to low and distortion, total Harmonics and stuff like that. I want to make sure I'm getting speakers that will work okay with the current reciever untill i buy a new one sometime next year. I'm just not sure what all the lingo means. Can someone point me to a weblink or something that explains everything i need to know about buying the right speakers and this and that.
I'll post the info thats in my Manual for the current reciever I'm using plus the speakers I've already replaced for the new center and front ones in hopes that they are compatible or at least won't destroy the reciever untill i buy a new one when ever. But i guess the most important thing is learning the lingo so i can make good buying choices in the future.
Here's the specs the current system according to the manual:
Panasonic SC-Ht900 Hometheater Specs:
38
RQT6750
Specifications
AMPLIFIER SECTION
[HT900]
RMS Output Power: Dolby Digital Mode, 10 % Total Harmonic
Distortion
1 kHz Front CH 60 W per channel (6 ≠)
1 kHz Surround CH 60 W per channel (6 ≠)
1 kHz Center CH 220 W per channel (6 ≠)
100 Hz Subwoofer CH 240 W per channel (4 ≠)
Total RMS Dolby Digital Mode Power 700 W
FTC Output Power: Dolby Digital Mode, 1 % Total Harmonic
Distortion
120 Hz20 kHz Front CH 35 W per channel (6 ≠)
120 Hz20 kHz Surround CH 35 W per channel (6 ≠)
120 Hz20 kHz Center CH 140 W per channel (6 ≠)
45 Hz120 Hz Subwoofer CH 150 W per channel (4 ≠)
Total FTC Dolby Digital Mode Power 430 W
Input sensitivity/Input impedance
This system is supposed to be able to do up to 1000 watts but I don't see the calculations.
The replacement speakers I've attached:
1)Polk Monitor5jr{my 2 rear surround speakers replacements} specs:
Driver Complement
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Bass radiator (passive)
Midrange 1 - 6-1/2" Diameter (16.51cm)
Tweeter 1 - 1" Diameter (2.54cm)
Polk SL2500 dome tweeter
Electrical
Overall Frequency Response 30Hz - 25kHz
Lower -3dB Limit 48Hz
Upper -3dB Limit 23kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20-100 w/channel
Efficiency 90 dB
Dimensions
Cabinet Size 19-1/2" H x 9" W x 10" D
(49.53cm H x 22.86cm W x 25.40cm D)
2) CS150 Two-way Center Channel Loudspeaker{my center channel polk replacement} :
Driver Complement
Subwoofer 1 - 4-1/2" Diameter (11.43cm)
MW4800 bass radiator
Midrange 1 - 4-1/2" Diameter (11.43cm)
MW4802
SL4000
Electrical
Overall Frequency Response 100Hz - 20kHz
Recommended Amplifier Power 10 - 100 w/channel
Efficiency 89 dB
38
RQT6750
Specifications
AMPLIFIER SECTION
[HT900]
Distortion
Distortion
Driver Complement
Electrical
Efficiency 90 dB
Dimensions
Driver Complement
MW4802
SL4000
Electrical
Efficiency 89 dB
The specs are typical of all-in-one home theater systems. Adequate for bedrooms and small living areas at lower volumes. Any Polks will be an upgrade over the systems speakers, but will still be limited to lower volume usage due to the amplifiers capabilities.
Upgrading power to a better receiver/amp will be needed to get the most out of your new Polks.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
