How hot should my amp get?
Jim M
The back of my subwoofer gets very hot. I can touch it but how hot is too hot?
Post edited by Jim M on
when it starts smokin....it`s too hot !!
okay, really....
a little more info please
make, model, situation...etc.Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Well it depends on the design and how hard you are driving it but if you can still touch it for more than a few seconds then it is probably fine.The back of my subwoofer gets very hot. I can touch it but how hot is too hot?
ThanksTesting
Testing
Testing -
Thanks,
I have a polk sub model psw12 and denon 2307 receiver and do drive it a bit heavy at times. I had to send my amp to polk for repair and when I removed it from the sub case the insulation around the input for the lfe unfiltered input had melted all around the circuits. They replaced the amp and I got it back today and installed in and gave it a go and got a very hot panel on the back of amp. I removed it from the sub and it looks like the insulation is beginning to melt again. I have my receiver set to yes on the subwoofer and it gives me an option for LFE or LFE + Main. I use the Lfe option and have the frequency level set to 80. I use a single coaxial sub cable from the sub out on my receiver to and this is where I am a bit confused...there are two connections for line levels in on my sub one is yellow and sais unfiltered and the other is dual a red and white that sais line in filtered. If the insulation around the unfiltered input is melting should I be using one of the filtered inputs on the sub. -
Sorry but I'm a novice at this and learning as I go.
PSW 12 sub
Denon 2307 ci receiver
4 6" polk bookshelfs
1 125 watt polk center channel
14 gauge wiring
The insulation around my coaxial lfe inputs seems to be melting. Do I need to get a better sub or am I pushing the levels a bit much?
Thanks -
nothing should be melting.. if it is.. turn it off and call Polk Audio customer service.. you don't want to toast that subwoofer and you really don't want to start a fire either..PolkFest 2012, who's going>?
