Cheap tip
burdette
burdette Posts: 1,194
I did a little rearranging of the HT last night, and the result was that I had 6-8 wires/cables coming out of a wall running to the speakers and the TV - a little TOO exposed visually as well as within easy reach of my 2 year old. So, I used a couple of feet of foam pipe insulation as a wire wrap. This is the stuff that is meant for 1/2 inch copper tubing - it is black foam and is split along its length. I slipped all the wires inside and hid them.. now my setup not only looks cleaner, but there are no tempting wires for little hands to yank. I love cheap fixes that *work*. If you're looking for an inexpensive way to hide some wires.. the foam insulation worked slick, plus its very flexible.
  • gidrah
    gidrah Posts: 3,049
    edited October 2002
    Sounds great. For those that don't have pipe insulation around, RatShack and automotive installers also carry these things. No need for anything fancy.
    Make it Funky! :)
