Surefire G2
Mike682
Mike682 Posts: 2,074
edited September 2007 in The Clubhouse
Just picked this up the other day (black version).
http://www.surefire.com/maxexp/main/co_disp/displ/prrfnbr/878/sesent/00
Man this little thing is bright! I have a 3cell Maglite and the G2 is much brighter than the Mag. I still love the Mag and the Mag has its place in my collection. However, the G2 will be used more for outdoors as the G2's light relative to its size is impressive.
Just came in from using it around the yard and the neighbors. I really like the way the G2's beam lights up the yard and fills in shadows a good 100+ feet away. Not bad at all for a little light.
Highly recommend
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
  • Mike682
    Sweet!
    I bought mine at a local hunting store.
    Ours is rated at 65 lumens, I could only imagine what the G2 LED or the G3 looks like rated at 80 and 105 lumens.
    Mains: polk R30
    Center: polk CSi3
  • polrbehr
    polrbehr Posts: 2,877
    Smith & Wesson makes some nice little flashlights as well.
    The Tactical light is rated at 95 lumens, and is unbelievably bright for
    such a small flashlight. I also got a Galaxy 9, which at 65 lumens is no slouch
    either, but has the added benefit of 9 LEDs in addition to the Xenon bulb,
    which saves battery life considerably. You may want to consider something
    like that for your Dad, Sal. (BTW; you're welcome ;))
  • Face
    Face Posts: 14,340
    I use a similar light at work. The only thing I'm not crazy about is the cost of replacing batteries(123's). They do last a while though.
