Does This System work, Is it compatable with a 1998 Dodge Dakota
BigSubBoomer
BigSubBoomer Posts: 19
edited September 2007 in Car Subwoofer Talk
Ok so, im clueless and ambitious
Im buying a
Sub Boost Control 10 Band Equalizer
1000W 20ft Amp Lifier/amp Wiring Hookup Kit
2 12" pyramid 2400W (total so, 1200W seperate)Subs
Pyle 2 Chan 1400W Mosfet Car Amp
2 6 1/2" Speakers KFC-1690IE
My question is whether i will need either a cap or an alternator?
and is the amp compatable with both sub and EQ?
and do i even need the EQ?
And do i need to buy anything else not mentioned?
Post edited by BigSubBoomer on
  • MacLeod
    MacLeod Posts: 14,358
    How much are you willing to spend cause frankly bro, those are flea market brands youre talking about. Those amps are more like 500 watts maybe and those subs would catch on fire if you tried to push 1200 watts thru them.
    You get what you pay for in electronics and if youre willing to pay a little more, you can have an outsanding system. Give us an idea of a budget and we'll see what we can hook you up with.
  • Joelsbass
    Joelsbass Posts: 637
    Like Mac said, there's no way in hell you'd see those power ratings from any pyle or pyramid equipment... Even if they got struck by lightning I'd give it a 50/50 of whether or not you'd see that much power :p If you truly want to be ambitious give us a price range and we'll see what we can suggest
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • BigSubBoomer
    Oh well thank god for two things,
    this rating and the fact that they dont let me pick up
    anyway my budget for a system that needs to work (amp, subs and maybe converter unless amp has converter) is $160
    its limited, i know :(
  • MacLeod
    $160?!?!
    Jesus dude, that aint gonna buy you anything at all unless youre literally browsing thru flea markets.
    You should really save up a little more and get some decent stuff. Hell, $500 would be 1000 times better. At least with that you could get some solid entry level gear, but for $160 youre not gonna get anything really.
  • BigSubBoomer
    well my budget was $300 but i blew off 80 on a head unit
    im not lookin to compete im just lookin to go boom
    not even big boom
    just a little boom is ok
    but i just want it to be something that no one else in my area has
  • MacLeod
    A system for $160 - its pretty safe to say, youll be the only one with one of those.
    Youd probably be better off going down to Walmart or Autozone and seeing what theyve got.
    One thing for sure, with a $160 system, you definitely wont need a cap or alternator.
  • BigSubBoomer
    so you cant work any magic for $200?
    my only concern is that they will be considerably (a little) louder than manufacturers
  • MacLeod
    Can you build your own box?
  • BigSubBoomer
    yeah that i can do, thats what i was planning on doing, it was just gonna be a simple vacuum not bandpass or anything like that
    Please have some good news for me
  • MacLeod
    This is the best deal I can come up with on short notice and in good conscience. Two 12" Clarion subs for $100 shipped.
    Run it with this 400 watt Clarion amp for $130 shipped.
    Thats $30 over your budget but its the best youre gonna get and still have good quality, brand new in the box and straight from the manufacturer and fully authorized.
  • BigSubBoomer
    hey 30 dollars is not to bad
    now i noticed that its mono amp is that gonna be any problem with running and hooking up these amps or is everything gonna be good?
    and i noticed that the woofers on the subs are paper/fiberglass hows the durability on that? cuz i know paper durability sucks
    and would i need a wiring kit? my guess is yes
    and thanks so much by the way
  • MacLeod
    Mono will be hooked up just like any other. Youre just going to wire both subs positive to the amps positive and the subs negative to the amps negative.
    Those cones will be fine. They wont be the most durable in the world, but then again theyre only $50. Still they will sound good and be have good output and theyre good quality gear. Much better than some Pyle stuff.
  • BigSubBoomer
    well i cant thank you enough man seriously
    i appreciate only one morequestion about the wiring kit
    i will need one any suggested cheap things or places?
  • MacLeod
    Go to Walmart. Theyve got decent Scoshe kits dirt cheap.
  • BigSubBoomer
    do you suggest 8 gauge or not even
    and comparatively speaking whats the wal mart?
  • MacLeod
    If thats the only amp youre going to run, then 8 gauge will be fine.
    Whats Walmart? How do you now know what a Walmart is? WTF do you live?
  • BigSubBoomer
    no no no non ononon on on onn on onono nooooooooooooooooooooooooooo
    not that **** i need to re read or i sound like an idiot
    i mean what the price at wal mart so i can compare with ebay
    oh and if i run into some more money say maybe 50 dollars is there a decent pair of speakers i could manage to find?
    cuz running factory speakers with a sub may be out of balance
  • eloplayspolo
    eloplayspolo Posts: 1,117
    http://www.cardomain.com/item/PIOTSA1682R?vq_id=none
    I just had a buddy get those and he installed them on a stock infinity head unit and they sound crisp
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • MacLeod
    If you can find a dirt cheap wiring kit on Ebay, grab that. Wire is wire for the most part.
    x2 on the speakers Elapso or whatever his name is linked to. They wont be the best sounding speakers in the world but theyll sound better than the stock ones and theyre only $32!
    But for $50 + shipping you can have these Clarions so you could keep everything the same brand which I like to do.
  • BigSubBoomer
    wait do these come as a pair for $50 or as a pair for 100? the clarions i mean
  • eloplayspolo
    50 dollar clarions 2 ways over 67 dollar pioneer 4 ways???? are u out of your mind?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • MacLeod
    4 way speakers are stupid. Why do you need 3 tweeters per speaker???
    All it does is screw up the sound and have you paying for 4 extra components you DONT NEED!
    How many high end home audio speakes have 3 tweeters per speaker? None.
    A "beefy 1.5" midrange?" LMFAO
    So yeah, $50 Clarion 2 ways over $60 Pioneer 4 ways.
    And yes, those are $50 a pair.
  • 1996blackmax
    1996blackmax Posts: 2,436
    Nice to see you guys trying to work miracles for him :).
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Joelsbass
    MacLeod wrote: »
    Amen to that!
    Also for wiring if you can't find all that great of a deal on ebay check out knukonceptz.com great prices and good quality wire
    Josh: Damn skippy!
  • 1996blackmax
    Knukonceptz has very good products at very reasonable prices.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • eloplayspolo
    u think that a 2 way sounds better than a 4 way mac?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • 1996blackmax
    More does not alway = better, specially when it comes to speakers that have all this built into one.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • eloplayspolo
    o i know that, just my experience with pioneer 4 ways, which is owning a pair myself, my bro having a pair and recently my friend having a pair, they drive the music very well including the bass, its clean, the mids are kinda poor, but thats why u throw some 2 ways in the rear, im pretty picky when it comes to electronics, my TVs have to have a really high black level, my computer have to be the best or close to it when i build them, and when my dad gets a surround sound system or i help out friends with car stereos, we only want crisp clean clarity, i found that these little pioneers provide that.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • BaggedLancer
    BaggedLancer Posts: 6,371
    yikes, this thread gave me a headache reading and brings sadness.
    For $160 stick with the factory stuff for now. Go mow some lawns, pick some weeds, paint a few houses and get yourself $400-$500 to play with thus giving yourself a bit more of a market to play in.
    You gotta pay to play, and $160 just isn't gonna pay and you won't be happy with the end result.
  • MacLeod
    2 ways pretty much always sound better than 3 or 4 ways.
    Why would you want to split the high frequencies between 3 different drivers?? That makes no sense.
    To get the best sound you ideally want as few drivers as possible. A 6.5" midrange can play 40-4500 Hz easily and well. A typical 2" tweeter can play 2000-20,000 Hz easily and well. And by using only 2 drivers you drastically lessen the chance of any cancellation or phasing issues. Splitting the high end frequencies between 3 seperate drivers throws all that out the window.
    And that beefy 1.5" midrange is a tweeter. A midrange speaker that wont play below 1000 Hz is NOT a midrange speaker and Ive never seen a 1.5" driver than can without it sounding like a kazoo.
    Its a marketing gimick pure and simple.
    Like I said before, Ill give you $1000 for any SQ competition car, any reference level or any home audio system or any recording studio monitor system using "super tweeters". You aint gonna find any and there is a reason for it.
