Difference in drivers
Dave38
What's the difference's in the MW6503 and the MW6502?
Thanks.
Thanks.
Post edited by Dave38 on
Enough that you can't swap one for the other.Political Correctness'.........defined
President of Club Polk -
Why is that? It will still work.
You can also replace with any 6 1/2' driver. The point is there are differences in all Polk drivers and they are optimized to work in different speakers with different design parameters.
Will it work? Sure probably not to badly either. Are they a direct swap? No. Some of us, myself included, don't prefer to swap non- original drivers between models because there are differences. Also depending on what you are using for amplification certain combinations of MW drivers in conjucntion with certain x-over's can cause a problem and trip circuit protection because of certain load characteristics.
Is that a better explanantion?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Even if it would work it would sound different.
Polk does alot of research and developement in there speakers. They match them to the cabinets they are in and the speakers they will be paired with. Changing any of these parameters will change the sound.
With that argument you could use speakers of the same size and ratings from any manufacturer and say the same thing. -
Thanks for the replys. I was wondering if there was wattage and freq. response differences.
Plus, there are impedance variations on each driver which, if replaced with something different, will change the crossover points. The T/S parameters are different for each driver.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
See post #2.Political Correctness'.........defined
My answer, albeit short and sweet, was the correct answer. After that fact any details are as irrelevant as your last post. :rolleyes:Political Correctness'.........defined
How else can we get our post counts up???:D
BTW F1 you are right!! But you knew that already.:cool: -
The 6502 was used in the monitor 5 and smaller. It was still available a few years back when I needed one for an original monitor four (peerless tweet). Polk sold me the 6503s as replacements for the 6500 in my original monitor 10s (peerless tweet) and 6501 in my SDA 2s. The 00 and 01 were no longer available. This was all a few years back I don't know what they sell now. I haven't blown anything up lately.:) What happened to the parts charts?
