Damn A Tweak!!
Early B.
Early B. Posts: 7,900
edited September 2007 in 2 Channel Audio
Have you guys ever made some tweaks to your system and they sounded great for a while, but on some songs (even songs on the same CD), the pre-tweaked system sounded better? Then you end up in this endless twilight zone of tweaking in order to fix the problems that led to the last tweak. And you finally come to the conclusion that if you had left your system alone 8 tweaks ago, it would have sounded better than it does now. But, of course, you continue tweaking, and eventually realize that you have no idea what good music is supposed to sound like anymore, so you sell some gear that you said you never sell and buy some more of the same ****, and the cycle repeats itself. Ever done that?
OK, I realize this is nothing new. Just ranting about. And don't tell me to just sit back and enjoy my music. I'm a incorrgible tweaker and I ain't attending those damn Tweakers Anonymous classes.
"God grooves with tubes."
Post edited by Early B. on
    heiney9 Posts: 25,445
    Been there, annoying as hell.
    The REAL culprit of many, many frustrating listening sessions is the source material. As soon as you tweak for one recording to sound good another suffers. It's endless and can be extremely frustrating.
    I am constantly at the mercy of that little round reflective disc and what the authors decide to put on it. :(
  • SolidSqual
    SolidSqual Posts: 5,218
    I just bouhgt a $4500 dollar set of speakers after declaring 2 months ago that I had hit liquid with my Lsi15s. Hi. My name's Mike and I'm a tweaker.
  • Yashu
    Yashu Posts: 772
  • dkg999
    dkg999 Posts: 5,647
    The first step to salvation is admitting you have a problem :mad:
    I don't have no problems with upgraditus and tweakitus :eek:
    DKG999
  • danger boy
    danger boy Posts: 15,722
    two days ago my SDA 2B's sounded sweet and smooth and balanced.. now the left channel sounds louder than the right.. and the sound is way off.. I haven't really done any tweaking, they just sound like crap now.. what the hell is going on?
    So for two days i've been trying to recapture what good sounds... and nothing is working out right. I hate this.
    PolkFest 2012, who's going>?
  • hearingimpared
    hearingimpared Posts: 21,136
    Yep that is a real pain in the ballinis. Ted gave me a suggestion that I've followed religiously. I make a change, I don't say anything about it, I just listen for at least one full week. If I like it, it stays, if I'm not sure, give it exactly one more week. With this philosophy, I've staved off the initial WOW factor and have really settled down and confidently kept some things and dumped others.
    At one point I had so many upgrades and updates going that I was telling some of the local Polkies that by the time all the **** in my rig burned in I would be 60 years old, that's eight years.
  • danger boy
    For this reason I never introduce more than I new thing into the system.. add something.. listen for a couple weeks.. add or remove something... that way you aren't left to wonder which thing had the most positive impact. ;);)
  • Early B.
    heiney9 wrote: »
    Amen, brother. Blame it on the music.
    In fact, the effectiveness of most "upgrades" are at the mercy of the source material. We control the gear, but we have no control over the source material. The best we can do is find "audiophile-quality" recordings, but that's limited and does not include a sufficient number titles for all genres.
  • madmax
    madmax Posts: 12,434
    This is why you want to determine a tweaks success by playing a LOT of different music, not just the stuff that sounds the best currently. You normally end up giving up that last bit of perfection on the best sounding recordings to make everything else sound a little (sometimes a lot) better.
    Vinyl, the final frontier...
  • Early B.
    madmax wrote: »
    Agreed.
    I'll add that, if possible, do several A/B tests, going back and forth between different types of music. Otherwise, you can quickly forget what you liked about the pre-tweaked sound and get swept away by the "newer and better" sound.
    treitz3 Posts: 20,006
    Just a shot in the dark Early, but could this have anything to do with a certain pair of new speaker cables?
  • Early B.
    treitz3 wrote: »
    Partly. But I'm mainly referring to an IC that I changed out. Sounds great and I have no regrets, it's just that some songs sounded better on the pre-tweak. This form of buyer's remorse typically occurs after most tweaks anyway. No big deal. It siomply reminds me that no audio system in the world will give you everything you want with each song you listen to.
  • hearingimpared
    You may want to look at the songs listed on the album you are listening to. Many songs are not recorded in the same session so there may be some engineering and/or mixing changes done.
    Early B. wrote: »
    It simply reminds me that no audio system in the world will give you everything you want with each song you listen to.
    Unfu(kingfortunately!!!:mad:
    I have been known to tweak my rig for a half an hour+ just to hear one song or an album the way I like. Next song/album......it starts all over again. It's frustrating, but I deal with it........
    And it's worth it!:D
  • Ern Dog
    Ern Dog Posts: 2,237
    To complicate matters worse, I find that my mood or state of mind has lots to do with my listening enjoyment. When I'm in the zone, everything sounds good and I'm blown away how good it sounds and when my mind is distracted then my rig just doesn't hit the spot. I'm usually floating inbetween these extremes.
  • hearingimpared
    Ern Dog wrote: »
    I have the same problem. I can tell right away when it is going sour too; I start looking for something to read or start pulling at the wedgie that is forming, crossing my legs, recrossing my legs, oh yeah the symptoms are real.
  • Music Joe
    Music Joe Posts: 459
    madmax wrote: »
    x2
    With enough time you get an overall sense of something(s)
    added ,subtracted, loosened, tightened, warmed or brightened.
    Pouring a large amount of music through is a perfect all angles approach.
