Momo 6.5" Components
eloplayspolo
My TE1004 is out right now, anyone try running the momo components off a high end head unit like a Alpine 9885? it will still sound much better than my stock civic ones right?
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
eloplayspolo wrote: »My TE1004 is out right now, anyone try running the momo components off a high end head unit like a Alpine 9885? it will still sound much better than my stock civic ones right?
yeah, just don't turn the volume up too high, HU power is not clean power and you don't want to hurt your speakers with a dirty signalMacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
Dirty signals wont hurt the speakers so long as theyre under the speakers power handling.
Those Momo components can handle well over 100 watts per channel and your head unit, even fully clipped wont ever put out that much juice. Its just too small.
So yeah, a head unit will run those speakers just not as well as your amp and youll run out of clean power really quick but it will be fine to use until you get your amp fixed or replaced.polkaudio sound quality competitor since 2005
well i connected them, they dont sound bad at all, actually they sound great. What could the hiss comming from the tweater be?2013 Toyota Prius
Mosconi 6to8 v8 -
Switch the outputs on your radio and see if it switches sides. If it does its the radio. If it doesn't check the wire going from the crossover to the tweeter. Where are the crossovers mounted? If they are under the dash they can pickup radiated noise's from your cars electrical components and wiring.
Is it coming from only one tweeter?
If its coming from both, its probably just a high noise floor which is one of the problems with using head units for power.polkaudio sound quality competitor since 2005
