Wattage and watts per channel
aps1ngh
aps1ngh Posts: 36
edited September 2007 in Electronics
I've been doing a lot of reading on this forum and many others over the course of the last few weeks and a reoccurring statement I hear is the quality of wattage versus the quantity.
Before I moved to my new apartment, I had my used rt800i's wired to the lowest end Yamaha a/v receiver model from 3-4 years ago (my old roommates) and it was rated at 110 watts x 5 channels. The receiver was cheap (~$150 dollars refurbished) and the speakers sounded pretty decent at this setup. They did sound rather cold and I'm sure much better sound quality would be had with a better setup.
I am considering buying this NAD C352:
http://www.polkaudio.com/forums/showthread.php?t=57211
The integrated amp in question has a rated 80 watts x 2 channels.
I'm very inexperienced with owning decent home speaker audio equipment (other than nice headphones) but I know what I like to hear and I've demo'ed different setups here and there at audio stores and retail stores from time to time so instead of completely cheaping out I'm considering dropping some serious cash (I'm a college student) to buy this integrated amp.
To the point:
The impressions I've gotten is that from a high end audio company like NAD, I can expect a lot more sound quality and even volume from this integrated amp even though it's rated at a lower wattage because it is a much higher quality device.
Correct me if I'm wrong.
  • danger boy
    danger boy Posts: 15,722
    that NAD integrated amp will push your RT800i speakers just fine.... and yes your thinking is correct.
    PolkFest 2012, who's going>?
  • TroyD
    TroyD Posts: 13,124
    absolutely...quality over quantity, all things being equal.
    People get WAY too wrapped around the axle in wpc ratings. Consider this: to get a 3db increase in volume, you need to double the power. So the difference between 80 and 100 wpc is negligible.
    50wpc and a couple db of headroom is more power than most applications would ever require.
    BDT
  • Face
    Face Posts: 14,340
    Most of my listening is done under 3 wpc.
  • aps1ngh
    aps1ngh Posts: 36
    Does the same hold true in the the car audio industry or with subwoofers as well? I feel as if no (from personal experience) and also because of the different types of amplification (Class D vs A and B etc.). I'm not an electrical engineer, so my knowledge of resistance and electrical powered devices is very limited.
  • bknauss
    bknauss Posts: 1,441
    aps1ngh wrote: »
    To the point:
    What happens with the higher end company is that they will underrate their power output, distortion, and other ratings. Also, they like to overbuild their products a bit more. So with a NAD, you'll get a lot more power that stated, and its a more robust product. Yammie, on the other hand, will almost lie with some of their ratings and will build a product to meet a price, not a quality level.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • BaggedLancer
    BaggedLancer Posts: 6,371
    bknauss wrote: »
    Wait a minute, so a 7.1 receiver that does 130 wpc and weighes about 5 pounds is lying to me? Who would have known....
    (insert sarcasm here)
    mhardy6647 Posts: 35,562
    AFAIK, there are still Federal Trade Commission (FTC) regulations, first promulgated in 1974, that relate to power claims for two-channel (stereo) home hi-fidelity equipment. There are (again AFAIK) still no such regulations in effect for multichannel/home theatre equipment, nor for car audio.
    My everyday amp is a class AB, pentode-mode push-pull EL84 stereo integrated tube amp (EICO HF-81) which is capable of about 14 watts per channel at a reasonable distortion level and power bandwidth. Plenty for me with the speakers I use.
    These AK threads might be of interest(?)
    http://www.audiokarma.org/forums/showthread.php?t=124114&highlight=watts
    http://www.audiokarma.org/forums/showthread.php?t=122481&highlight=watts
  • Systems
    Systems Posts: 14,872
    bknauss wrote: »
    Yammie other hand, will almost lie with some of their ratings and will build a product to meet a price, not a quality level.
    Yammie may not be lying,but their ratings will most likely be based on driving an 8 ohm resistor.When you hook up a real speaker it certainly does not present a pure 8 ohm load so the rating is not realistic.On the otherhand as you mention NAD rate their products conservatively and are usually capable of driving a 4 ohm load.
    Testing
    Testing
    Testing
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    NAD is fine company and you should enjoy your gear no matter what it is, however, you are thinking correctly about the amperage or current supply being a part of the equation of any fine audio system.
    RT1
  • Willow
    Willow Posts: 11,371
    RT1
    I was going to say something along those lines. With your NAD, you will be getting high current amperage.
    I had yamaharxv540 rated at 80wpc. My hk335 is 50 or 55wpc. the HK blew the yam out of the water. I think it's partially due to better parts as well s the high current 35amps.
  • bknauss
    GV#27 wrote: »
    Well, Yammie doesn't technically lie. What they do is measure the receiver in stereo mode. They then take that power output and put "x5" or "x7" on the end of it. The receiver could never ever perform with that much power. Now you take a brand like NAD or Adcom, and they will hit those stated numbers and most likely do a good percentage more.
    Brian Knauss
  • bknauss
    There are a ton of loopholes in that, especially when you apply it to multichannel receivers. But that is what Yammie is doing more or less (among other companies. I don't have it out for them). They do the FTC rating for stereo, and then add how many channels are on the receiver.
    But like most things in life, pay the money for the good stuff. Its worth it in the end.
    Brian Knauss
    treitz3 Posts: 20,367
    aps1ngh wrote: »
    I would, but you are correct.;)
  • Systems
    bknauss wrote: »
    Which is precisely what I meant when I said NAD rate their products conservatively, so we are in agreement:)
    Testing
    Testing
    Testing
