Outlaw 2150/M2200 combo
Serendipity
Serendipity Posts: 6,975
edited September 2007 in 2 Channel Audio
Hi,
I'm interested in the Outlaw 2150 receiver and M2200 monoblocks for my dorm room setup. I'm wondering what kind of improvements I will get over my current Onkyo TX-SR702 receiver, especially for music.
Will be paired with either Definitive Tech BP10Bs or SVS SBS-01 bookshelves.
Thanks!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • cfrizz
    cfrizz Posts: 13,415
    I would think that you will see considerable improvement especially with the addition of the amps.
  • Lowell_M
    Lowell_M Posts: 1,660
    I would suggest looking elsewhere if you are concerned about music. There are plenty on the forum that like the Outlaws, but I have been less than impressed when comparing my H/K receiver to the Outlaws and then other amps. The Outlaws offered a bit of detail and more clean power, but did nothing for depth of soundstage, imaging and separation.
    There are plenty of recommendations in different threads here. At the moment I'm partial to ADCOM. Awesome performance for the price. You could find a GFA-555 for around $300 - $400.
    There are lots of others out there. I just happen to have experience comparing the ADCOM to the Outlaw's.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Serendipity
    a_mattison wrote: »
    I've actually had an Adcom GFA-535 and didn't hear much of an improvement over the Onkyo TX-SR702 receiver I currently have. In fact, I felt the Adcom was a bit too bright or "forward" sounding.
  • Lowell_M
    Ok, to each their own. There is definately something to be said about synergy between components.
    I would characterise the GFA-555 in my current setup as anything BUT bright. There is a very nice detailed top end that isn't harsh or bright, excellent separation and imaging overall and a VERY solid bottom end. It makes my RTi70's do things I didn't think they were capable of.
    Be sure to post your impressions of the combination of components you come up with.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Serendipity
    a_mattison wrote: »
    The Onkyo receiver I have has a very bright preamp section, so when combined with the adcom (which has a nice top end) I had quite a bright sound. Not that it was harsh or anything, but I think it's mostly due to the Onkyo's pre section being bright from the start.
    As an alternative to the Outlaw combo, what else would you guys recommend? Currently looking at the Adcom GFA-555 amp and Outlaw 2150 pared together.
  • Serendipity
    As an alternative, how about the Parasound A21/A23? Would that better suited for my (mostly) music application?
    Just looking at other options...
  • cfrizz
    Yes that will work as well. Parasound makes solid gear!
  • engtaz
    engtaz Posts: 7,669
    Great way to go. you won't be disappointed.
    engtaz
    heiney9 Posts: 25,446
    appadv wrote: »
    It's the Onkyo being used as a pre. You will probably find everything is on the bright side just because of the Onk. Experimentation is the key, but don't just discount one particular brand when it hasn't been used in more than one configuration. The pre amp (IMO) is only second to the source in a system. The receiver being used as a pre is probably the next weak link.
    That being said there are many, many choices out there and I agree 100% with a_mattison about the Outlaws. Greta for HT but as far as I'm concerned not that great with pure 2 ch music.
    YMMV
    appadv wrote: »
    Another good choice, but may sound bright as well because of the Onk being used as a pre.
  • Serendipity
    heiney9 wrote: »
    I like my Onkyo's sound though. Even though it's a bit bright I still like the sound very much.
    What if I used a Parasound P3 as the pre? It seems to cost the same as my Onkyo yet is in a different league...
    Would like your opinions.
    appadv wrote: »
    Don't have any experience with the P3 so I can't say. In my experience a dedicated 2 ch pre is usually a better sounding piece. What about the Onk do you like? Are you talking about it as a receiver or as a pre?
    It's unfortunate that sometimes you have to swap some gear out to find out not only what you like but what works well together.
    I have had several Adcom pieces and have to yet to hear they are overly bright. They are very detailed and will reveal any source or weak links in the chain, but we all have our preferences for whatever reason :)
  • Serendipity
    heiney9 wrote: »
    The Onkyo as a receiver sounds wonderful, but as a pre it sounded bright. I also like the fact that the Onkyo (as a receiver) has a quiet noise level and a very wide dynamic range.
    I also read that the Onkyo puts out some solid power (56W/ch) with all channels driven, and 115W/ch in stereo mode. That's not bad considering most AVRs are overrated these days.
