NAD or Musical Fidelity for 2 Channel
Polkitup2
Polkitup2 Posts: 1,642
edited September 2007 in 2 Channel Audio
I currently have a NAD C370 integrated but am looking for something with HT Bypass. I have had my eye on the Musical Fidelity A3.5 but have not been able to hear one. Has anyone had the opportunity to compare NAD with the Musical Fidelity? Just wondering if I would be making a lateral or vertical change in sound quality if I went with the Musical Fidelity A3.5
Post edited by Polkitup2 on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I've compared both in home (along with Cambridge Audio). I had the Music Hall A25.2 and the NAD and CA around the same price. I preferred the MF over the other two, so I kept it and then bought another for my other 2 channel system.
    I've moved since then, but I'll go back and see if I can find my review notes. One thing that I do remember, and the main reason I kept the MF, is that the MF sounded better at lower volumes.
    EDIT: Wow, completely misread the title and then continued using the wrong name for my equipment throughout my post. My stuff is Music Hall, not Musical Fidelity (although I do have a Musical Fidelity X-CAN v3 and X-DAC in transit to me as I write this). However, my impressions and comparisons were with my Music Hall gear. I've no experience with Musical Fidelity as of yet.
  • Polkitup2
    Thanks for the edit, I appreciate the effort.
  • AndyGwis
    AndyGwis Posts: 3,655
    I have owned my Musical Fidelity A3.2 (similar to the newer, more powerful 3.5) for maybe about a year. I love it! Looks great, very musical, GREAT build quality. All around, a solid performing piece of gear. Full function remote, very musical, powerful, etc. Great at low and high volumes. Plenty of bass, even out of my Thiel 1.2s. Probably my favorite piece of gear ever (but also my most expensive).
    I have had many Nad amps over the past couple years as well. Solid performers, great value, but I didn't think they were quite in the same league as the Musical Fidelity 3.2. Also, not nearly as good looking.
    Disclaimer: I like shiny things and my IQ is 78.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • unc2701
    unc2701 Posts: 3,587
    The A3.5 kinda falls in a weird spot in my opinion. The X-150 has almost the same power supply (but no HT bypass) and the A5 is hands down, waaaaay better. If you didn't need the HT, I'd say go with the X-150.
    Have you considered the krell kav-300i? You can set one input to HT bypass via an internal jumper & on the used market it's about the same cost as the A3.5 Unfortunately, it's also got a "questionable" power supply.
    Backburner:Krell KAV-300i
  • Polkitup2
    Thanks guys. I am thinking if I want to make the step it should be the A5 or Krell 400xi, or Rogue Audio, or ???
  • AndyGwis
    The A300 from MF can often be found for cheaper than the A3.2, and offers a bit more power, if I'm not mistaken. Maybe add that to your list.
    It does have a gold knob, but I don't think it looks bad at all.
  • Chicomoralessxm
    Chicomoralessxm Posts: 417
    Just a question what about the CA840? Just an idea. Not sure if it has ht bypass though i'd have 2 check on that........
    Chicomorales:)
  • dorokusai
    dorokusai Posts: 25,576
    I'm a NAD fan but sonically the MF has the edge, no question. It has much better dynamics but you can't lose either way.
    Aesthetics wise, NAD is a shy wallflower and the MF is a pimped out ****.
  • Chicomoralessxm
    dang...........not thats an analogy
    Chicomorales:)
  • beardog03
    beardog03 Posts: 5,550
    once again, Doro is quoteworthy !
    and while I do enjoy a wallflower on ocassion, I am definatly into pimped ot hoes !!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Midnite Mick
    Midnite Mick Posts: 1,591
    beardog03 wrote: »
    Who isn't?
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • markmarc
    markmarc Posts: 2,309
    I've heard both side by side, the MF digs deeper and is clearer/cleaner IMHO. But, it is more $$. If possible, do yourself a favor and audition both in your rig, it's the best way to know what will suit you best.
    Former Staff Member TONEAudio
    2 Ch. System
  • dorokusai
    I would swear that there was someone who didn't like the MF in their rig....anyone remember who?
  • know nothing
    know nothing Posts: 24
    I listened fairly critically to the 370, A3.5 and A5 through B&W 603s and CM7s and some Paradigm towers (don't recall the model). I agree with most of the other posts hear, the MFs sounded better across the board, although the Paras sounded pretty good in combination with the NAD. The Musical Fidelity gear is just a lot more sophisticated and nuanced than the seemingly muted presentation of the NAD. The A5 is a noticeable step up from the A3.5.
    Correct me if I am wrong, doesn't the NAD have a plastic face plate? That's a problem for me, but may not be for you.
    Aside: I really liked the voicing, soundstage and looks of the new B&W CM7 floor standers. The synergy between these speakers and the MF A5 CDP and amp was special.
  • AndyGwis
    Anything that comes with a 1/4" or thicker aluminum faceplate is a nice piece of gear in my book.
    My Theta Pro has like a 1/3" thick aluminum front (maybe even thicker). No wonder their DACs sell for $1500+ retail.
    My MF looks great and has a wonderful asthetic appeal to it as well.
  • Emlyn
    Emlyn Posts: 4,727
    dorokusai wrote: »
    Isig sold a MF A5 integrated because it didn't have good synergy with his SDA-SRS.
  • beardog03
    I am starting to get the MF itch again..!!
    I wonder how it will mate with my current setup?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
