adcom gtp-350 issues
steelervic
steelervic Posts: 142
edited September 2007 in Electronics
i have an adcom gtp350 tuner/preamp, when i have it switched to a source other than tuner if i turn up the volume i can slightly hear the radio bleeding through. anybody know if this is normal?
thanks, vic
    heiney9 Posts: 25,724
    steelervic wrote: »
    thanks, vic
    It's called crosstalk and it's a normal phenomenon. Your cables or power cord may also be picking up a radio station. At one time I had that problem and I didn't even have a tuner. Moved up to better cables and it was solved.
    Since the GTP is a tuner/pre it's probably bleeding thru and shouldn't affect performance too much. I'm guessing you only hear it when there is no music signal playing and when the volume is cranked and you are close to the speakers??
    This is an exact illustration of what seperates can do for you. :)
