Problem with HD-DVD player
Home Theatre
I have the Toshiba HD-DVD player. It works great for movies but when I play a cd it had slight pauses. The music still plays but there is a pause.
Anyone have any idea.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
I'd using a cleaning disc or something.
My bedroom HD-A2 had issues playing HD-DVDs without skipping, would play SD DVDs and CDs just fine. Had to send it in to get it fixed.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
This is weird. Movies play fine. I am going to rewire everything on Friday night. I am getting digital cable on Saturday morning.Everything I own burned in the fire!!!!!!!!!!
I'd try one of those cheap $10 lense cleaners just to be sure it's not just some dust.
When I had my Pioneer DV-59avi, I couldn't get it to play the SACD layer of any combo discs. I would read everything else fine, and it would play SACD only discs fine. I must have messed with the settings for hours over a 2 month period, rewired, posts all over the web. After all that, I used a 5 year old scotch lense cleaning disc and it worked perfectly after that.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
i had that issue also but when i updated it went away. maybe your firmware is not entirely up to date? lens cleaners won't work because the laser is also used for movies, which you stated work just fine.At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
