Speaker Cable Help
cmy330go
cmy330go Posts: 2,341
edited September 2007 in 2 Channel Audio
What would you guys recommend for a reasonably priced set of speakers cables that are also aesthetically pleasing. Would like to stay under the $100 mark.
I'm looking for a 10ft pair for my Dad's new system which consists of a Music Hall MMF-5 Turntable, Bellari VP129 phono stage, Cambridge Audio 540C CD player, Sound Quest SQ-88 Tube integrated, and Energy RC-10 speakers.
BTW. I'm also OK with a good used set.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • dkg999
    dkg999 Posts: 5,647
    I would go with Signal Cable, but you'll probably push over the $100 limit for 10' cables. I use the Blue Jeans Beldon gray 12g cable for my HT system, and it's pretty neutral sounding. The Canare S411 is also pretty neutral sounding and at around $2.25 a foot or so is in your budget.
    DKG999
  • janmike
    janmike Posts: 6,146
    Lots to select from but for your budget I would go with SC as well. My entire HT has SC and you cannot beat it for the price. You cannot go wrong there IMO.
    Michael ;)
    NORTH of 60°
  • pearsall001
    pearsall001 Posts: 5,092
    Mapleshade Golden Helix. Right in your price range. Don't let the size fool you, these babies bring it in spades. http://www.mapleshaderecords.com/audioproducts/speakercable.php
  • Face
    Face Posts: 14,340
    How about used cables? You can check out audiogon.
  • cmy330go
    Just out of curiosity, have you ever done any direct comparisons between the Helix and anything else? I've often wondered about their products, but have never tried them for whatever reason.:confused:
    HT
    2 CH
  • pearsall001
    cmy330go wrote: »
    I still have Signal Doublerun speaker cable, Canare 4S11 bi-wired speaker cables, a few others from various companies. Once I put the Mapleshades in my system I've had no desire to take them out. I was quite surprised to say the least!! :) Enough said. Give them a try (30 day return policy) nothing to lose. That's the only way to find out 1st hand.
  • cmy330go
    Not sure he'll care much for the look of them, but I think I'll order a set to try. Heck if he doesn't like them maybe I'll use them on my system.:D
    HT
    2 CH
  • JimBRICK
    JimBRICK Posts: 1,543
    Solid Link Speaker Cable
    http://www.responseaudio.com/unity.htm
    I got a pair of these for 65 shipped off ebay. Brand new in the box. I see them on there regularly
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • pearsall001
    cmy330go wrote: »
    That's the only way to find out if you'll like how they sound in your system (or your dad's). Especially with Pierre's 30 day trial policy you have nothing to lose. I'll bet you really like them though.
