Humm
nikolas812
The Power Wire is the funky looking green and red wire.
This is a fairly common problem when you add a high powered amp. There is a ground loop somewhere in your system.
Now you can go the long way around & unhook all your connections one at a time until you find out which piece of equipment is causing the hum, or you can go to a hardware store & get a 3 prong to 2 prong plug & plug the amp into the plug & the plug into the wall or protector.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks for the advice. But I think I found the problem. If you notice the white and orange cables all secured togeather there are white ones and a orange one. The white ones are the stereo interconnects and the orange one is the digital connect. When I unhooked my digital wire the humm went away. I haven't seperated the two yet but I hope it solves the problem. I think I will also do the plug thing any way, I personally think it should have a ground no matter what.
nikolas812 wrote: »Thanks for the advice. But I think I found the problem. If you notice the white and orange cables all secured togeather there are white ones and a orange one. The white ones are the stereo interconnects and the orange one is the digital connect. When I unhooked my digital wire the humm went away. I haven't seperated the two yet but I hope it solves the problem. I think I will also do the plug thing any way, I personally think it should have a ground no matter what.
There is nothing wrong with the way your interconnects are together. I think the problem runs deeper than just seperating the wires. The interconnects look to be shielded very well. So I dont "think" it will help to seperate them. But I hope I'm wrong. Good luck.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Well I seperated the stereo wires from the digital one and plug the digital cable back in and still got the humm. Does this meen I have to do the ground thing for my plug?
I think my dvd cd player also might be on its way to giving out. I got it off of ebay and it never was really right from the begining. -
Change out the digital wire, see if that helps.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
if you can use an optial wire for you digital, go that route, no ground loop that way
I had a terrible hum from my Parasound when I first hooked it up. Had to use a cheater to lift the ground from the amp. No hum after that. None of my other gear had grounded cables, so maybe it all needs to be grounded, or all ungrounded. Not sure, but this was the first time I had a problem like that.
Well I tryed a different digital wire and still have humm. I can't try my optical wire because my preamp does not accept optical:( I kinda hope grounding the plugs will fix it.
Whats a cheater -
I would guess that the digital out on the player has a small short in it somehwhere.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
That is the term we use for the 3 to 2 prong plug I told you about, since it is basically cheating the grounding to take away the hum.
There are other more expensive, time consuming ways to find out & eliminate the annoying dreaded hum!
I just prefer cheap & easy!:Dnikolas812 wrote: »Whats a cheaterMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I have had a similar problem and used a cheater plug to find the problem. I did not like the idea of plugging in my equipment through a cheap cheater plug so I just broke the ground prong off and solved both problems. I did this on the stock cord so no big loss. I will probably build new cords and I have seen plugs with removable third prongs which I would probably use if need.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Thanks for everybodys help.;) Hopefully I can get it fixed.
