which is the better sub amp?
ilikesound
an alpine mrp-m450, 22w rms @ 4ohms, 400w rms @ 2 ohms, OR
JL audio 250.1 amp, specs unknown...
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
Post edited by ilikesound on
Depends on the sub.
If you have a 400 watts DVC sub, the Alpine.
If you have a 250 watt sub, the JL.polkaudio sound quality competitor since 2005
Jl 250.1 is 250 watts at 1.5,2,3,or 4ohms. Anywhere in there and you get 250watts. Also the JL will give you the power from 11volts to 14.5 volts. The Alpine will give you full power at 2 ohms only and at 14.4 volts. I would say regardless of sub I would go with the JL audio.
