Port on same side as woofer?
McLoki
McLoki Posts: 5,231
edited September 2007 in DIY, Mods & Tweaks
I was just wondering for a DIY sonosub, is there a reason the port cannot be on the same side as the woofer? (i.e. rather than the woofer on the bottom and port on the top - put them both on the bottom)
I have never really seen any plans this way but think it would be much easier to make the woofer act as an end table if the top was solid. (Now can I find a form 24" in diameter or so?)
Just wondering why most of the designs you see have the woofer on the bottom and port on the top.
Michael.
  • Systems
    Systems Posts: 14,872
    McLoki wrote: »
    Michael.
    I think it is mostly a matter of having the space for both on the same end.There is no technical reason they can't be.
    Testing
    Testing
    Testing
