CD burning...
steveinaz
steveinaz Posts: 19,547
edited September 2007 in The Clubhouse
What is a good but very simple CD burning program?
  • Mike682
    Mike682 Posts: 2,074
    My laptop came with a program called "Sonic RecordNow!". It is a very basic burning program that is very easy to use.
    I also have Nero which has a huge amount of options and can take a little more time to get used to.
    The RecordNow program is simple, however, you may want to look into something with a little more options for future projects.
    Mike
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Nero, Roxio, Sonic, hell even windows xp comes with burning software for CDs by default, just use windows media player. All the same but I'd saying the windows xp one is easiest to use.
  • Mike682
    good call, I always forget that windows xp has a burner program
    Mains: polk R30
    Center: polk CSi3
  • steveinaz
    cool thanks fellas.
  • janmike
    janmike Posts: 6,146
    I find Nero works the best.
    Michael ;)
    NORTH of 60°
  • bobman1235
    bobman1235 Posts: 10,822
    iTunes also has CD burning if you're into that program at all.
  • Willow
    Willow Posts: 11,370
    Another vote for Nero
  • cfrizz
    cfrizz Posts: 13,415
    I use XP for burning my cds. It doesn't get much easier, and I like easy!
  • audiobliss
    audiobliss Posts: 12,518
    How exactly do you use XP for burning CD's?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • bobman1235
    audiobliss wrote: »
    Like this.
  • audiobliss
    Thank you!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Greg Peters
    Greg Peters Posts: 605
    I've had Nero, prefer Roxio (which is now owned by Sonic RecordNow)...prefer Roxio, but more the way it was pre-takeover FWIW.
  • Shizelbs
    Shizelbs Posts: 7,433
    Nero FTW
  • audiobliss
    Can you COPY a CD using the XP burner?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • PolkThug
    PolkThug Posts: 7,532
    My Zippo works pretty good at burning CD's.
  • beardog03
    beardog03 Posts: 5,550
    PolkThug wrote: »
    wwwaaaaaaaaaaaaaaaaaaaa
    not bad for a nice guy !
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • audiobliss
    Hahahaha. Thanks for the tip...where can I buy a zippo? :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • beardog03
    I have used a program called `ahead nero` with good results
    I would like to find the one that came with the Dell computer at work, but I can`t remember te name of it right now
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • I-SIG
    I-SIG Posts: 2,243
    iTunes has been as simple as it gets.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • BottomFeeder
    BottomFeeder Posts: 1,684
    I-SIG wrote: »
    Wes
    But when I burn a cd and a friend uses it in his computer, there are no song titles recorded at all.
    How can I fix this???
    "Wish I didn't know now what I didn't know then." Bob Seger
  • bobman1235
    You mean the title and artist information?
    You can't fix that. Audio CDs do not hold that information. You could burn a disc full of MP3s, which would keep that info but you wouldn't be able to play it in your car or on standard CD players (unless they had MP3 capability).
    heiney9 Posts: 25,715
    Steve I will also add if you are doing your own ripping then Exact Audio Copy (EAC) is the absolute best ripping program out there if you want bit perfect rips every time. It's free ware, safe to download, etc. I've used it exclusively for years.
    Here's a link.
    Wikipedia for some background info:
    http://en.wikipedia.org/wiki/Exact_Audio_Copy
    Home Page:
    http://www.exactaudiocopy.de/
    It's virtually flawless when ripping (grabbing) audio files.
  • audiobliss
    EAC is a great program. I had forgotten about it.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BottomFeeder
    bobman1235 wrote: »
    Arg!
    But thanks!
  • fatchowmein
    fatchowmein Posts: 2,637
    For EAC newbies using mp3's, this is a great link for setting it up. http://chrismyden.com/bestmp3guide.php
    Modify the instructions accordingly if you don't want to use mp3 format. Remember, EAC also does WAVE. Technically, it does wave first and encodes to mp3 on the fly.
    As for burners, I mostly use Nero Express. Probably out of habit more than anything else.
  • Greg Peters
    bobman1235 wrote: »
    I find if I add the ID3 tag info after ripping (I use winamp, but Windows Media player will let you do the same thing) to add artist/song title info, whether I burn an .mp3 or regular .wav disk, the titles still show on my Alpine (car) and my wife's Sony (home), and the disks play fine on both counts. Older CD players won't support this feature, but many from this decade do.
    I've actually purchased a few retail audio CDs that contain track info as well.
