audio stand help
JimBRICK
Hey guys, I need your help. I keep finding all over those audio tower type stands but what I'm looking for is a longer one kind of like a sofa table.
maybe 55 " wide by 36 inches high. Where I can put my componants lengthways side by side So I could put my amp on the top part and two componants on either side. Has anyone seen something like this
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
I have honestly never seen anything like that.Expert Moron Extraordinaire
too bad this is going to be a hard find2 CHANNEL
Under construction -
Do a search for "Flexi-Rack."
Or maybe buy a heavy sofa table.:D
Trouble with that is if the wife decides to hijack it.
A flexi rack might not be the best choice for long
shelves and heavy weight.
I've been seeing a lot of longer audio/video racks for
for supporting HDTV's, but always with a shelf.
Might be time to try some better furniture consignment shops.
Then you'll have to see about creating a vibration control scheme
that works. Like Russman's floating CDP stand."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Jim, have you ever checked out some of the Plateau furniture. I like some of it and the price is right.Michael
NORTH of 60° -
Sofa tables typically aren't very deep and IMO would look a little weird with full size components on it......might look better with a mini-shelf system........comment comment comment comment. bitchy.
anonymouse wrote: »Not exactly what you are looking for... but may fit the bill:
http://www.kmart.com/shc/s/p_10151_10104_021W566897110001P?
Awesome! thats pretty damn close to what I'm looking for. thanks for the suggestions guys2 CHANNEL
Just a FWIW -
I built a rack very similar to that -
With SOLID wood and veneered plywood and spent like 30 dollars more...
DIY is a great option.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
