An electronic incident this afternoon
Midnite Mick
I go to fire up the system in the usual patient process that firing up tubes take. I turn on the source, then the pre (muted)...let them warm up for a bit and then fire up the monoblocks. As the monoblocks are starting up I start to hear some noise out of the speaker and them see one of the 6922 input tubes flash.:eek: :mad: I quickly turn the amps off followed by everything else.
After letting everything cool I then hook up the preamp to the Aragon amp and when I unmute the preamp there is noise coming out of the speakers. I have had noise come out of the speaker before when I needed to replace the preamp tubes. Obviously, the amp tubes and the preamp tubes wouldn't fail due to use at the same time.:mad:
Can a failure to an input tube on an amp cause damage upstream in the preamp? Could a problem preamp tube cause an amp input tube to fail? Could there be more problems than just the tubes?
Help....advice please.
Thanks,
Mike
Thanks,
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Consonance cd120T
Usher CP 6311
