Blown amp help
analog97
analog97 Posts: 328
edited September 2007 in 2 Channel Audio
I'm sure somebody had this happen! I just blew an amp channel (Anthem solid state) while playing my wonderful 1.2 TL's. Drats!! GLAD IT WAS NOT A SPEAKER!! Anyway, could this be as simple as a fuse that governs one of the channels? Or, is it likely that a component blew? This happened because of short between the 2 speaker binding posts for the blown channel (copper stranded speaker wire touched during play)....yeah, I know. Any thoughts greatly appreciated. TIA!!
Post edited by analog97 on
    heiney9 Posts: 25,204
    analog97 wrote: »
    Probably a fuse....check and replace, if it blows again w/o a short then there maybe other damage as a result.
  • danger boy
    danger boy Posts: 15,722
    i'm guessing a fuse too.. open her up and see if the fuse(s) are good.. it's tough to tell sometimes.. those fuse wires are so thin. good luck though.
    PolkFest 2012, who's going>?
  • analog97
    analog97 Posts: 328
    Yes, took Danger's advice and opened it up. Found a bad fuse on the bad channel's board. Now, gotta find my magnifying glass and see if I can read it. I will replace and see if nothing else is wrong. Hope I get lucky. Thanks!
