Where Do You...
cfrizz
Get your replacement ink cartridges from?
I have a Brother MFC 420CN. I need to get a black cartridge. I have never spotted them in any local store, so that leaves getting it online.
So where do you go, & do you get remanufactured ones or original ones?
Try here http://www.inkquik.com/brother_lc41.html?OVRAW=Brother%20MFC%20420CN&OVKEY=brother%20mfc%20420cn&OVMTC=standard&OVADID=4551325512&OVKWID=50110146512 or here. http://www.brother-usa.com/accessories/Accessories.aspx?Model=MFC420CN&ACASCID=30Get your replacement ink cartridges from?
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
It might be time to upgrade that dot matrix printer to something a little newer Cathy. I bet you still have a 10" green CRT....
http://www.123inkjets.com/index.htmlCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Ms. Frizz,
let me know if you have no luck with those two links in a pm on Monday..
I`m the Sr, Buyer at work , and have a few Vendors that I could look up...(If I still have the info)!!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Ebay.
Great prices for OEM cartridges that rival the remanufactured ones, which I tend to stay away from, unless it's laser toner.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Ebay.
laser toner refill is the shite
Here's a link for an outfit that is pretty cheap (plus "Buy 2 Get 1 Free" deals):
http://www.clickinks.com/showproducts.asp?categoryid=30008&SSAID=BMFC420CN&gclid=CJ-S_IvPto4CFRUHWAodFjpNxA
Save 25% off the Singles with our Super Saver 11 Pack
This Pack contains
5 x Black LC41BK Compatible cartridges
2 x Cyan LC41C Compatible cartridges
2 x Magenta LC41M Compatible cartridges
2 x Yellow LC41Y Compatible cartridges
$44.45, looks like free shipping.Sal Palooza -
It's an ink jet smart mouth! And since I got it for free, I'm certainly not going to complain!:p
http://www.123inkjets.com/index.htmlMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I ordered from Clickinks.com. Thanks fellas.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
