Psw 12 Problem-keeps Shutting Off
Jim M
Jim M Posts: 4
I'm having a problem with my subwoofer I purchased in Jan. 07. It is under warranty but if I can solve problem through forum so much the better. When I am listening to music that has a lot of bass in it the sub will shut off after a few minutes of play and if I turn the switch to off position and back on again the sub will start working again but only for 20 seconds or so. I only have the volume at the middle level. I haven't had any trouble when watching a movie when there is a lot of sub use. Any help would be appreciated.
P.S. I have a new denon receiver and don't think there is a problem there.
:confused:
Post edited by Jim M on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited September 2007
    My gues is you are pulling to much current from your wall outlet what you should do is take a volt meter and cheack the voltage befor and while you are blasting music.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
