new install problem
lda2345
yea so i put my new stuff in today. mtxte1501, mtxte1004, and two polk sr 12dvc's. ok so now my sub amp shuts off after about 10 minutes of playing it. i beleve its going into protect because i do not have enough power going to it. im runing 0gauge all the way from the battery to the amp. i have a 2000 v6 accord. im thinking about repacing my red top under the hood for 2 kinetik batteries or just put one in the trunk and keep the red top under the hood. i realy dont want to replace my alternator. any suggestions would be helpfull.
SR 4 Life
Post edited by lda2345 on
my TE1004 had that same problem out of the box, only it wasnt lack of power, it was another issue, im going to send it in in the next few days, it doest turn on at all now.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
just wanted to say you and i have the same car. i think that amp might be faulty. mine has never had that issue, and im still using the stock battery/alt until money can be spent on an upgrade..im running 4awg and using a dist. block as well, for a sub amp and im not having problems..any other amps in your setup?At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
What ohm load are you presenting to the amp?
to answer your questions no just the mtxte1501 and mtxte1004, i am runing the sr's at 1ohm. yea so today my amp just decided to not **** work anymore. it was working fine (shuting off every 5 to 10 minutes) untill about 5oclock then it decided when i turned my car on to suck the subs in and to blow my fuse in the dist. block. i checked sum stuff and its def. the amp im sending it back to mtx tomaro. and now it dosent even power on anymore. THIS SUCKS!!!! ilikesound what setup are you runing in your car?SR 4 Life
also what are some basic rules for setting up fuses in a vehicle. at the battery and the dist. blocksSR 4 Life
1 as close to the battery as possible, run power through your car untill your cap or dist block, your cap and dist block act as a fuse, then your good.2013 Toyota Prius
Mosconi 6to8 v8 -
what are the amprage rules for the fuses is what i ment to saySR 4 Life
What size power wire are you running?
300A fuse within 18" of your battery, then another fuse by the amp if the amp isnt fused. That fuse size can be determined by the recommended fuse size for the amplifer from the manufacturer.
my setup is as follows:
front: Focal k2p component midrange, with polk MM6500 tweeters in a-pillar, bi-amped with polk c400.4
rear: MM690 (not hooked up)
sub: MM2084 8'' amped with Alpine mrp-m450 (220w rms)
EQ: cadence peq-860
Head: Alpine CDA-9857
IPOD
14awg wires, jlaudio rca's and interconnects.
here's some photos. at the time i write this, the trunk has been re-done with some form of carpet that has glitter all over it. it looks really cool, like a star-field in the middle of space or something like that. just thought it would be unique. i have also added the cadence peq-860 which has three variable bands of eq under the head unit itself. the custom a-pillar picture can be found in this thread, it won't let me upload a previously uploaded pic for some godforsaken reason.
http://www.polkaudio.com/forums/showthread.php?t=56699At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
