electrical dudes, circuit breaker question for ya
jrlouie
I was hoping someone more educated in this type of stuff could give me their opinion. I'm wondering how instantaneous a circuit breaker on a surge protector/conditioner is. For example, the surge protector has a breaker on it stating that it will open if its power draw exceeds 15 amps. Does that essentially include a brief peak type of situation too? In other words, if that puppy never opened, could I say I have never drawn 15 amps from the wall through that conditioner?
Please see pic for reference.
Not a circuit breaker 15 amps constant or more like 10 amps constant for a blink of an eye maybe something around 100 amps before it would trip. The same is true with Slo-Blow fuses acting like a CB, but fast act fuses don't like in rush current so would blow where a Slo-Blow fuse wouldn't.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
DJ7 is right. You could have peaks well over the rated 15 amps but are of such short duration that it never gets near the time-current curve of the breaker.
On a larger scale, the fuses that the power companies use can handle thousands of amps, but only instantaneously, usually in either an in-rush situation that dj7 mentions, i.e. the power has been out for a couple of hours and everyone's A/C kicks on or in a fault situation that is of such short duration the fuse never has time to melt. Don't get into ground fault detection on distribution systems....:o
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I have replaced more circuit breakers then I care to remember ( In the manufacturing area I support we use a LOT of robots moving large assy's...one particular tool set uses these robots in a water enviroment ...those I usually find melted
) As mentioned above, the breakers can take a much higher instantaneous current for low millisecond pulses...but a tiny bit longer in duration and they trip. Also, the more cycles they are tripped...they tend to trip at a lower current level the next cycle...and so on. Here is a quick link to show how the common ones actually work . http://electronics.howstuffworks.com/circuit-breaker2.htm The first rule of Fight Club is you don't talk about Fight Club -
In general, anything that has a transformer or winding like an electric motor is called an inductive load. When voltage is first applied to an inductive load the wire in the windings acts like a straight piece of wire, or for illustrative purposes a short, so it draws a bunch of current. As the current starts to flow it creates a magnetic field that radiates out from around the wires at a 90 degree angle. As the magnetic field passes through adjacent windings it induces a current in opposition the the initial flow of current in the winding of the coil. This opposition to current flow reduces the initial inrush current and eventually limits the amount of current that passes through the winding. If you have ever seen lights dim in a garage when an air compressor kicks on or in the house when a washing machine starts its cycle you have seen this phenonmenon in action. Consequently circuit protection devices have this condition accounted for and designed into them. In some industrial applications there are circuit breakers used that have a time delay adjustment. Again, this is a very simplistic explanation.
(If you hold a pencil in your hand to represent a conductor with your fingers wrapping around it and your thumb pointing down its length, your thumb indicates direction of current flow and your encircled fingers indicate the magnetic lines of force radiating out of the conductor. The magnetic lines passing through a conductor next to the first one would have a current induced in it that flows in the opposite direction.)The Beloved System:
Parasound Halo P3 Preamp
Parasound Halo T3 AM/FM Tuner
Grant Audio Tube Buffer
ADC Sound Shaper II IC Graphic Equalizer
Polk XRT12 XM Satellite Radio Receiver
2 Carver TFM 35x Power Amps
Harmon Kardon T45 Turntable w\ Benz MC 20E Phono Cartridge
Vincent Phono Preamp (not enough gain in the Parasound Phono In)
Cambridge Audio 640C V2 CD Player
Nakamichi BX300 Cassette Deck
Polk RTi 12 Main Speakers
2 Polk PSW 1000 Subwoofers
