Will rti4/rti6 match with CS2?
rajeshberi
rajeshberi Posts: 2
edited September 2007 in Speakers
I've Polk Audio CS2 center speaker. Just wanted to know if rti4 or rti6 would be a good match for front mains? I've read reviews saying that rti's are much better than monitor series! Help!
Post edited by rajeshberi on
  • ohskigod
    ohskigod Posts: 6,502
    the RTi's are a step up in model line up. the CS will not be timbre matched to the RTi's. might work as a stopgap, but you will eventually want to upgrade to the CSi center (preferably the 5, never go small with your center.)
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • rajeshberi
    rajeshberi Posts: 2
    Thanks for your response. Would it be better to go with Monitor speakers instead?
